Old 27th April 2007, 12:22 AM   (permalink)
NiCAD are often 800mah where as NiMH are much higher current capacity 2600mah is not uncommon.
Bill
Home of the
Firefly PIC Tutor
Inchworm ICD2
William At MyBlueRoom is offline
Old 27th April 2007, 12:29 AM   (permalink)
Hmm, well I don't know if you know this store, it is called Giant Tiger. Just some cheap stuff here, and most of the times it is not all that bad. The batteries that I saw had "For Solar Powered Lamps" thing on them.
Since I am not going to be a using a voltage regulator and expecting the stuff to run on the 4.8-5V batteries, do you think I will be spending more time recharging then actually testing the robot? Because if it drains too quickly, the batteries might go into the unusable output voltage range and so I'd have to discharge and recharge.
So right now, is this my best solution... running the things off four NiCd batteries?
Omar.M is online now
Old 27th April 2007, 08:21 PM   (permalink)
I think that four cheap NiCds is probably your best solution. The NiCds will stay near 4.8V until they are almost depleted.
As for spending time recharging, I suggest two sets.
You mention discharging as if it were a part of recharging.... I maintain that discharging is a colossal waste of time and effort. A "memory effect" is really uncommon in normal use. I have a lot of NiCds in use, for a long time, and have never experienced it.
mneary is offline
Old 28th April 2007, 12:26 AM   (permalink)
In 'normal' use yes memory is rare. I think Nasa had a big problem with it because the charge cycle occured at exactly the same point in a batteries discharge state and it eventually developed a voltage dip at that point. NiMH's and Nicads alike will have a similiar problem with a generic charging circuit in things like cheap cordless phones. Because a lot of the time they're only used for a very brief period of time and then thrown on a charger again, these chargers are seldome fit to know the cell was only depleted only a fraction of a percent of it's charge and they tend to constantly trickle charge the batteries, which is just as bad.
straight answer, har har."
Sceadwian is offline
Old 3rd May 2007, 10:35 PM   (permalink)
Souper man
Originally Posted by blueroomelectronics
I'm running the Mongoose directly off the 4x NiMH batteries. I have a 1N5819 diode to avoid reverse polarity for the PIC. Works fine. No Need for 9V.
The only 9V rechargeables I could find were NiCAD @ 250mah.
O GOD!
Cadmium is seriously bad for environment, although its already pretty messed up.
Good example is lake erie in the 1970s lol!
Old 3rd May 2007, 10:56 PM   (permalink)
Well I don't like NiCAD, I use NiMH when I can find them.
Bill
Smart Kits build Smart People
Old 7th May 2007, 09:48 PM   (permalink)
The best deal I've seen for NiCad batteries is from Maplin
A real NiCd D cell 5500mAh for just £2.98!
http://www.maplin.co.uk/module.aspx?...=32624&doy=7m5
Screen name: Aloone_Jonez
Hero999 is offline
Old 8th May 2007, 12:34 PM   (permalink)
Nicads aren't as energy dense or light as NiMh's but they're much more robust. Some RC fanatics still use them because they source current better. That's a very good price, especially for a D cell, I'd snap some of them up. Great for high current portable supplies.
Old 9th May 2007, 12:14 AM   (permalink)
If you can afford the size and weight of NiCd, then consider gel-cell (Sealed Lead Acid). 20% larger, 30% heavier, less than half the price.
D-sized 5500 mAH, £2.99 x 5 = £15, 4.8 oz x 5 = 1.5 lbs.
6V 4.5 AH Gel cell, £5.99, 0.9 kg.
mneary is offline
Old 15th May 2007, 08:00 PM   (permalink)
Wow I'm supprised no one has mentioned Li-Poly batteries yet, why is that? Are they not as good for robots? (Well besides the fire hazards and stuff) Because I use these for micro airplanes and such and they seem like they would be ideal for small lighter weight robots.
psecody is offline
Old 15th May 2007, 08:30 PM   (permalink)
Li-Po's cost too much for hobbyist robotic enthusiasts (mostly). Also they need constant monitoring of the cells so that it wont blow up destroying the whole robot. Robots tend to be a lot more expensive than RC equipment (depending on the robot of course). And the miniature weight of the cells is normally not needed. If they are, then the robot is poorly designed and the mechanics should be redesigned.
Need Help?
Press F1
If that doesn\'t help you, ask me... I might know better.
bloody-orc is offline
Old 16th May 2007, 12:15 AM   (permalink)
Check out FMA Direct. They are a bit expensive, compared to regular NiMh's or NiCads, but weight aside the physical size is an advantage. They also sell discharge controllers which sense cell voltage and activate cut off circuitry before the pack can be damaged. The packs and the chargers are designed to work together and the seperate charge cable from the discharge cable feeds into temperature/voltage sensative voltage elements which automatically ballance the packs.
www.fmadirect.com
If you need, or want the highest possible amount of energy storage in the smallest amount of space and weight lipoly's are the way to go. As bloody-orc stated though they're pretty pointless for your run of the mill line follower or bounce off the walls and wander around robot.
constant voltage, constant current Lead Acid Battery Charger Erwin_Macaraig Micro Controllers 1 4th October 2008 12:26 AM
primitive early design for battery charging faomari General Electronics Chat 3 2nd May 2006 03:22 PM
Armada m300 smart battery reset nio General Electronics Chat 1 21st January 2006 05:40 PM
Replacing a Battery DirtyLude Electronic Projects Design/Ideas/Reviews 5 13th July 2005 12:55 PM
Connect Battery and PSU at same time...? grrr_arrghh General Electronics Chat 3 9th July 2004 11:20 PM
