Wow. See why I love Toronto? If my dollar store was to have any, the 'NiMH' batteries would be alkaline ones with a NiMH wrapper. Ottawa is expensive(er)!
I think I might as well do that. Hopefully I'll find some cheap chargers with batteries around here. I've actually heard that PA has those too, with chargers. If I can find those then I'm in luck eh? Thanks for your help, will keep you posted. Omar |
Expensive best buy $27
http://www.bestbuy.ca/catalog/prodde...0&catid=22206# And I think I saw this sort of thing at ToyRUS for about $12 awhile back. ![]() |
Do not use the diode across the supply pins.
The diode goes from battery +ve to the +ve supply pin of the PIC, pointy end to the PIC. If you inadvertently apply the power supply backwards, no current can flow. The schottky ensures only a small voltage drop from battery to PIC. |
get the diode as close to the battery pack as possible on the PCB. if you connect it only near the PIC then only PIC will survive and all other things will burn
Need Help? Press F1 If that doesn\'t help you, ask me... I might know better. |
That was the most amazing trip I have had to a store-- ever.
Okay, I've been in PA and I thought it was like paradise for me before, PA never seems to surprise me. So I was looking through the aisles, and soem chargers caught my eye. There was a WHOLE SECTION deticated to this. And they have everything, Energizer Chargers for about 9.99 and even a cheap little NiMH / NiCad charger for 4 DOLLARS! I picked it up but put it back, I am going to go back once I pick up some NiMH batteries. So my parents wanted to shop, and we stopped at some big store. Behold, there was a wall filled with NiCad batteries. 2 for $1.97. Woah. That was the coolest thing ever. So, I picked up so much stuff from PA (stuff I didn't even dream of getting today). Aye well, I'll go back there next weekend and buy the charger. I'm still a little suspicious of the charger. It just looked like a generic charger, black and nothing much written on it. It did have NiCad / NiMH charger (with charging times) written on it. Should I trust this one? Thanks a lot you guys! Omar |
It's probably fine. PA is pretty neat, bought my digital calipers there.
It's probably a "stupid" charger then. you must make sure that the AA batteries you are going to charge are as empty as possible to avoid memory effect (that NiCad batteries have). also you must make/have a timer to make sure you wont overcharge those little bastards (or undercharge).
So every time I want to recharge the batteries, just hook each up to a motor until it is almost drained THEN recharge?
The timer shouldn't be much of a problem, I may need to calculate exact times though. So other than this memory effect (which should not be a problem if I nearly drain the cells each time and do not under/over charge), is there any other problems with these NiCad batteries? -Omar |
Modern NiCads shouldn't have a memory effect prominent enough to be worth all that effort.
IMHO, the risk of damaging the battery by reverse charging one cell in a pack is greater. |
Oh ok. Thank you VERY much
I think I will go with the NiCads then. Bill discussed this, but it seems that there is no LDO voltage regulators at Active Electronics (my only electronics supplier around here). So for the LM7805 regulator I currently use, I do need an input voltage of above 7.5V. Bill said he connected the PIC directly to the power supply (with a diode for the ripple regulation). I don't think this will work for me, 6V-- isn't the PIC made for just 5V? Are there any solutions? I am thinking of giving them a call and seeing if they have any LDO voltage regulators in stock (that are not listed on the website). Omar |
NiCAD & NiMH are 1.25V per cell. 4x1.25=5V
AYYEEE! Me being stupid again, I just overlooked that. I thought they were 1.5V like the alkaline rechargeable batteries.
Silly me, thank you sir! |
NiCh/NiMh = 1.2V Lead Acid = 2V Normal non-rechargeable = 1.5V |
for my experience the recharger batteries have 1.36V in them (NiMH at least). this is on the very edge of the PIC voltage range (5.44V) so a 0.7V drop on a normal 1n4148 diode makes it all good
anyway good luck PS yes the memory problem seems to be a little problem, but better safe than sorry you know
The cells are probably cheap because they come from a batch that don't meet spec in some way, such as meeting the advertised capacity, integrity of the envelope, etc. |
| primitive early design for battery charging | faomari | General Electronics Chat | 3 | 2nd May 2006 03:22 PM |
| Armada m300 smart battery reset | nio | General Electronics Chat | 1 | 21st January 2006 05:40 PM |
| Replacing a Battery | DirtyLude | Electronic Projects Design/Ideas/Reviews | 5 | 13th July 2005 12:55 PM |
| constant voltage, constant current Lead Acid Battery Charger | Erwin_Macaraig | Micro Controllers | 0 | 4th January 2005 09:35 PM |
| Connect Battery and PSU at same time...? | grrr_arrghh | General Electronics Chat | 3 | 9th July 2004 11:20 PM |
