Hi all, I need some help with selecting the suitable heatsink for my wirewound resistor. model : HS10 75R J datasheet : http://docs-europe.electrocomponents...6b8003123a.pdf Is the power rating of the resistor 10w for any voltage applied? I'm going to apply 24V to the wirewound resistor, can intro me to any heatsink suitable for the job? Thanks in advance. | |
The power dissipated by the resistor depends on the resistance and voltage across it. Use ohms law.
i mean in the datasheet, it says the power rating is 10watts, what does that actually mean? and do i really need a heatsink for that kind of resistor. if yes, could you please tell me which type should i use? Thanks in advance | |
The power rating is the maximum power it can dissipate without being damaged. The size of heatsink you require is determined by the amount of power the resistor will need disipate in the circuit. To find out how much power your 75 hm: resistor will dissipate with 24V across it, use ohms law; see above.
| | #5 | |
| | #6 |
Thank you | |
| | #7 |
Dough, I wanted him to figure it out for himself so he would learn from the experiance and you've gone and ruined it now Ron!
| | #8 |
Hey Hero, I like that ohms law graphic, I think I'm going to print it and make some coasters with it, would make a nice conversation piece. The nice solid colours will make it easy to pretty in GIMP too. It's slightly amusing that the letters on each quadrant starting from the upper left going clockwise spell 'wire'
| | #9 | |
![]() I guess I should have fed some hints instead of the answer. Hopefully, he'll go to the datasheet and try to figure out where I came up with those numbers. Are you listening, forever99482? Last edited by Roff; 23rd March 2007 at 04:34 PM. | ||
| | #10 | ||||
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. | |||||
| | #11 |
thanks everyone ![]() but then i found out that the wirewound resistor is not hot at all after i plug in the 24V @_@, so I'm just sticking to it without a heatsink. | |
| | #12 | |
| | #13 |
Perhaps the internal resistance of his power supply is so high the voltage drops enough.
| | #14 |
haha, wire Where do you get all your pretty pictures hero | |
| | #15 |
| heatsink, selecting |
| Introduction to High Brightness LEDs and Thermal Management | Ocelaris | Electronic Projects Design/Ideas/Reviews | 3 | 17th March 2007 06:35 AM |
| Mounting MOSFETs on heatsink | Electronics4you | General Electronics Chat | 12 | 18th January 2007 12:56 AM |
| Problems with Dual Brightness (Current) LED Tail Lights? Eagle Schematics! | Ocelaris | Electronic Projects Design/Ideas/Reviews | 12 | 31st December 2006 07:18 PM |
| How to calculate what heatsink to use. | Exo | Electronic Projects Design/Ideas/Reviews | 4 | 27th April 2005 10:04 PM |
| Determining correct heatsink size to use. | mozikluv | Electronic Projects Design/Ideas/Reviews | 4 | 16th August 2003 03:35 AM |
