Old 1st March 2007, 04:53 PM   (permalink)
Arrow alternative for (infrared) motion detecting switch?
We're working on a motor driven web cam that detects the motion of user and folllows the user within the field of view. Our problem is we first used an infrared motion detecting switch, so it basically just sends a 1 or 0 if it detects body heat or not. This sensor is not so accurate if we want to really focus on the user's face. (the cam has base that rotates and can also tilt)
The main goal of this project is to focus the camera to the upper half body, much preferred the face (as this is focused during web chat). So using the switch as sensor is not really the best option right? We're really running out of time what can we possibly do to remedy this?
What sensor can you suggest we use? Thanks!
guen_max is offline   Reply With Quote
Old 2nd March 2007, 04:32 PM   (permalink)
Use a small array of the sensors - one in the center and 3-4 surrounding it. If the heat is detected in the center, it's good, if heat is detected in the side ones, then move the camera until only the center detects it.
Or put the pyro sensor on another scanning stage, and swing it around so you can tell where the person is. You'll also need to limit the field of view of the sensor so that it's about 'head-sized'.
Face tracking is typically done in software, but trying to integrate one in at the last moment is a bad idea.
hjames is offline   Reply With Quote
Old 5th March 2007, 04:47 PM   (permalink)
thanks hjames, we'll consider what you suggested!
Old 6th March 2007, 05:52 PM   (permalink)
Default for motion sensor
hello we need a circuit for a human body are there that time light will glow and when person will go out side than auto off after 30sec. so plz tell me what i use
ninja is offline   Reply With Quote
Old 7th March 2007, 02:23 AM   (permalink)
Just look for a motion detecting switch. I'm sure you'll find it stores where lighting fixtures are sold. Models vary but usually it outputs a 1 if motion is detected, and 0 if none.
Old 8th March 2007, 10:47 AM   (permalink)
Hi guen_max do you think you are solving the question by any means??
mvadu is offline   Reply With Quote
detecting motion fugrammer Robotics Chat 3 9th December 2006 05:59 PM
PIC Switch Management Techniques Mike, K8LH Micro Controllers 2 28th September 2006 12:33 PM
Motion activated ON/OFF switch for Science Fair project klytle Electronic Projects Design/Ideas/Reviews 5 18th January 2006 04:33 PM
motion switch oliphant Electronic Projects Design/Ideas/Reviews 6 10th September 2004 11:10 PM
Infrared Motion Switch needed urgently! tim_l_012 Electronic Projects Design/Ideas/Reviews 1 1st October 2003 06:40 AM
