| Hi, I'm now just over a year into construction of a AUV/ R/C Sub hybrid. I've been working on the electronics for a while now, and have started to hit some brick walls. I've figured it was probably best to start a thread that post here and there. Current progress can be seen on my site: http://mhims.co.uk/sub/AkulaGepard/Index.htm I'm hoping to have the hull,propulsion, ballast system and essential electronics woking by end of April time. The problem I'm faced with at the moment: The main batteries are 6 6V 162Ah sealed deep cycle lead acid all wired in series to give me the 36V I need for the main drive motor. I'd like to be able to monitor the voltage across each battery however I've no idea how to go about this. I was thinking a 'heavy duty' (high voltage?) opamp using as a diff amp with wires coming from the postive and negative terminals of each battery.....Am I on the right track here or is there something I'm missing? The problem I have is that it's not reletive to zero volts..... Can any one help me please? I started elec. lessons sept last year, but we've spent far too long (for my liking Cheers, Michael | |
| You could use differential inputs to measure across individual batteries, but if they are in series, and presumably charged in series, do you really need individual readings?. | |
| I'll take them out for charging and so each one will be charged separately. It's just while they're onboard that I'd like to monitor each battery. Michael | |
| I would suggest it would be FAR better charging them all in series as they are used. | |
| But then how would I ensure that every battery is fully charged? Michael | |
| But these batteries have been on standby for a year or so and I'd like to look after them as much as possible. BTW it's four isn't it? 4 x 1.5V = 6V? Michael | |
| | (permalink) | ||
| Oops, anyway, if I do charge them up in one lot I guess it'll save on buying lots of chargers Michael | |
| You said sealed lead acid packs? Is there any access to the internals? If you find a cell imbalance it can likely be corrected by adjusting the sulfuric in the individual cells. If they don't charge equally then something is obviously going on with the internals, especially if all the cells were bought new at approximately the same time. This is only likely to occur after a long period of time, or abuse. The reason I ask is because we have a 24volt fork lift at work that has 12 lead acid cells (2 volt single cells not sealed) we have to check the water levels every month and the sulfuric concentration needs to be tested every 6 months or so because it's a very abused power source. As the the primary operator I can be using both main hydraulic functions, plus full steering assist and have the accelerator on the floor all at the same time.
__________________ "Because I be what I be. I would tell you what you want to know if I could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." Last edited by Sceadwian; 30th January 2007 at 03:27 AM. | |
| Himszy, I love the way you got the buildings to look life like. Mike. ![]() | |
| Sceadwian, I can't honestly say. I'm picking them up in two weeks (postage on 180kg of batteries is quite alot I hear Michael | |
| FINAL YEAR PROJECT! | erique82 | Electronic Projects Design/Ideas/Reviews | 18 | 15th April 2007 11:09 AM |
| Project for me, you. | jat45 | Electronic Projects Design/Ideas/Reviews | 7 | 11th January 2007 04:04 PM |
| Problem with my Project: Motorised volume control | zenigame211 | Electronic Projects Design/Ideas/Reviews | 20 | 24th March 2006 02:43 PM |
| A Microcontroller based Analogue Waveforms Analyzer Project | km | Electronic Projects Design/Ideas/Reviews | 76 | 30th June 2004 07:40 PM |
| I need a project idea based on my strength or interest. :) | janetsmith2000@yahoo.com | Electronic Projects Design/Ideas/Reviews | 10 | 11th November 2003 10:33 AM |
