Old 14th January 2007, 08:05 PM   (permalink)
Default need help wid project
WIRELESS ROBOT ::--
well for starters im trying to build a robot which will be interfaced with the PC using RF module.
and then using the RF reciever along wid the microcontroller or some other controller to control the forward ,backward etc movements.this is level 1.
if im able to complete this within the time then the next enhancement tht i would like to do is to put a camera in it n take the images back on PC n tht also wid the help of either RF of bluetooth.this is level 2
last but not the least is to implement a robotic arm also in it so that it can also act as an industrial automated robot.this is level 3
1--which RF module to use as there a lot available.any specific tht anyone has used ????????
2--what do u think is this project worth making ????
3--any idea or suggestion to any changes???
4--should i use VB scripting or labview software for the purpose of interfacing??
LoSeR
LoSeRRR is offline
Old 14th January 2007, 08:25 PM   (permalink)
1. Zigbee or Zigbee Pro from Maxstream (www.maxstream.org)
2. I don't like purely tele-operated robots so I would say no. I personally only think it's worth it if there is at least some autonomous control present (the Mars rovers were both semi-autonomous and tele-operated). But it's really up to you isn't it?
3- Add on some autonomous functions that maybe could be switched back and forth between manual (maybe like macros or something) You already have a microcontroller onboard...might as well add at least a sensor or two. So you don't always have to be guiding it the whole time.
Probably the largest reason for manual control is the arm...it's very hard to find a way for the robot to navigate and control the arm on it's own and decide what it should do with the arm.
4- No idea.
dknguyen is offline
Old 14th January 2007, 08:52 PM   (permalink)
hi
i am making a teleswitch ( remote control using telephone )
ihave tried the following circuit with amodified version. ihave used 47 k,680k registers ,470 &102 pf capacitor to generate 10 Kz tone for the ring back tone . i have used a 220 to12 v step down transformer with a diode and filter capacitor to give a 12 volt dc supply.But it is still not working. By pressing 0 button the telephone does not move to appliance mode .Can you just help me out someway within today?
description of the circuit is given below:
Here is a teleremote circuit which enables switching ‘on’ and ‘off’ of appliances through telephone lines. It can be used to switch appliances from any distance, overcoming the limited range of infrared and radio remote controls.
The circuit described here can be used to switch up to nine appliances (corresponding to the digits 1 through 9 of the telephone key-pad). The DTMF signals on telephone instrument are used as control signals. The digit ‘0’ in DTMF mode is used to toggle between the appliance mode and normal telephone operation mode. Thus the telephone can be used to switch on or switch off the appliances also while being used for normal conversation.
The circuit uses IC KT3170 (DTMF-to-BCD converter), 74154 (4-to-16-line demult-iplexer), and five CD4013 (D flip-flop) ICs. The working of the circuit is as follows.
Once a call is established (after hearing ring-back tone), dial ‘0’ in DTMF mode. IC1 decodes this as ‘1010,’ which is further demultiplexed by IC2 as output O10 (at pin 11) of IC2 (74154). The active low output of IC2, after inversion by an inverter gate of IC3 (CD4049), becomes logic 1. This is used to toggle flip-flop-1 (F/F-1) and relay RL1 is energised. Relay RL1 has two changeover contacts, RL1(a) and RL1(b). The energised RL1(a) contacts provide a 220-ohm loop across the telephone line while RL1(b) contacts inject a 10kHz tone on the line, which indicates to the caller that appliance mode has been selected. The 220-ohm loop on telephone line disconnects the ringer from the telephone line in the exchange. The line is now connected for appliance mode of operation.
If digit ‘0’ is not dialed (in DTMF) after establishing the call, the ring continues and the telephone can be used for normal conversation. After selection of the appliance mode of operation, if digit ‘1’ is dialed, it is decoded by IC1 and its output is ‘0001’. This BCD code is then demultiplexed by 4-to-16-line demultiplexer IC2 whose corresponding output, after inversion by a CD4049 inverter gate, goes to logic 1 state. This pulse toggles the corresponding flip-flop to alternate state. The flip-flop output is used to drive a relay (RL2) which can switch on or switch off the appliance connected through its contacts. By dialing other digits in a similar way, other appliances can also be switched ‘on’ or ‘off.’
Once the switching operation is over, the 220-ohm loop resistance and 10kHz tone needs to be removed from the telephone line. To achieve this, digit ‘0’ (in DTMF mode) is dialed again to toggle flip-flop-1 to de-energise relay RL1, which terminates the loop on line and the 10kHz tone is also disconnected. The telephone line is thus again set free to receive normal calls.This circuit is to be connected in parallel to the telephone instrument.
please reply on jayatasnuva@yahoo.com
Electricity is offline
FINAL YEAR PROJECT! erique82 Electronic Projects Design/Ideas/Reviews 18 15th April 2007 11:09 AM
A Microcontroller based Analogue Waveforms Analyzer Project km Electronic Projects Design/Ideas/Reviews 76 30th June 2004 07:40 PM
Choosing a PIC for my project... Beef41 Micro Controllers 6 19th March 2004 04:47 PM
I need a project idea based on my strength or interest. :) janetsmith2000@yahoo.com Electronic Projects Design/Ideas/Reviews 10 11th November 2003 10:33 AM
findin out for an innovative project bewra Electronic Projects Design/Ideas/Reviews 2 26th September 2003 11:42 PM
