Hi everybody:
I have a small problem concerning the H-bridge L298 since am building a line following robot and am using the L298 H-bridge… the problem which am facing it that I only need to use 1 input from phase A and 1 input from phase B and to be more clear I only need to use pin ( 5 & 10) and still I have 2 input pins free " pin ( 7 & 11) so my question is it safe to connect these pins (7 &11) to the ground or connects the pins (7-5) & pins (10-11) with each others and then use the 2 inputs as 1 input ?? if there is any idea please post it and thanks a lot Data sheet here: http://www.st.com/stonline/products/...re/ds/1773.pdf
AY |
Do you need bi-directional control? It seems the way you want to control your robot is to have either a left motor on, a right motor on, or both motors on (forward). Why not just use two transistors and save some time? On the other hand, if you do want to use the chip, just tie pins 7 and 10 to ground. Then you can use Pin 5 for one motor and Pin 12 for the other.
I hope that helps!
-Ian |
ya I thought before about ur idea but dunno it didn't work properly so i bought the L298 but i was wondering abt these inputs...anyway i will connect them to the ground directly and thanks a lot for your help
Ahmad,
AY |
| Basic Transmission question | CamNuge | General Electronics Chat | 2 | 8th March 2006 10:08 PM |
| Question about rectifier bridge | wat | Electronic Projects Design/Ideas/Reviews | 14 | 1st December 2005 08:47 AM |
| High speed data logging question | cubdh23 | Micro Controllers | 3 | 19th August 2004 11:54 AM |
| Data Logging question with high speed!!!! | cubdh23 | General Electronics Chat | 4 | 16th August 2004 06:33 PM |
| PBX question | waqar | Electronic Projects Design/Ideas/Reviews | 0 | 30th March 2003 06:21 PM |
