Old 24th September 2006, 01:55 PM   (permalink)
Default SErvo motor to be attached to wheels
hello...
i really need anyone's help rite now. im currently working on a line following robot. i ve built the pic16f877 circuit and i already built the IR circuit. Rite now, i have one doubt. the actuator. i have a couple of Hitec HS311. n i dont wanna spend more on buying motors. Can i use those Hitec servo motors as the actuator, to move the robot? i already hacked it. what i should do next? thanks.
LameMe is offline
Old 24th September 2006, 07:43 PM   (permalink)
It's not often someone asks a question after they have already done the hardest bit!
If you already hacked the servo for continuous rotation just stick some wheels onto the hub. Send a regular servo PWM pulse to control the servo speed. "Center position" is stop. 0 degrees is "full speed CW. 180 degrees is "full speed CCW".
You already did the hard part. Just make sure the robot isn't so heavy that the servos aren't strong enough.
dknguyen is offline
Replacing RC Servo w/ Custom PCB (Open Servo) dknguyen Electronic Projects Design/Ideas/Reviews 3 29th May 2006 03:48 AM
Help required with servo motor controller mayhem Robotics Chat 3 26th May 2006 05:21 PM
Servo Motor Help Needed!!!! potpotpotpot Robotics Chat 10 10th May 2006 08:54 PM
how to attach to servo output shaft? NleahciM Robotics Chat 1 29th June 2005 07:17 PM
Determining lifting capacity of a servo Jerran Robotics Chat 4 24th October 2004 11:53 PM
