Old 16th August 2006, 03:20 PM   #16
Inches Per Second - spinning a stepper is fun, but rapid'ing the CNC world's "mine's bigger than yours" comparison.
hjames is offline
Old 16th August 2006, 03:46 PM   #17
IPS. Wouldn't that be based on the diameter of the gear at the end of the stepper shaft?
Or is IPS based on a standard gear size?
I have not tested this IPS, but from math.....does the following make sense?
(Driver at 1/8 step. Motor 200s/r or 1.8deg. Gear Perimeter 2.25")
So each full turn of the shaft, the motor travels 2.25".
With a STEP signal of 60Khz...
60Khz/(200 steps/rev) = 300 Turns in 1 sec...
So if my stepper is turning 300 times in 1 sec....
And my travel distance in 1 rev is 2.25"
Thats 675"... Somethings wrong?
That's 56'
I'll have to try it out?
Again with the IPS.
Is that based on a standard step signal, or gear size?
I just feel there are too many variables to compare IPS.
Matilda is offline
Old 16th August 2006, 05:25 PM   #18
It's assumed that the stepper(or servo) motors are already installed in the CNC setup, and the measurement is relative to the machining head. At some point steppers will start to torque-out(i.e. miss steps) and it can't be used above that point. It's not supposed to be a serious question...
hjames is offline
Old 16th August 2006, 06:01 PM   #19
inches per second, cm per second.
philba is offline
Old 16th August 2006, 06:31 PM   #20
Oh OK.
Hey I'm newbie....just learning the ropes.
The gantry that is driven by these steppers is not allowed to run past 5"/sec. That is a spec'd concern from my customer.
I know it's going 5"/sec.
(Looks slow to me)
End user is happy & he likes the smoothness.
Thats all that counts I guess.
Thanks guys
Matilda is offline
Old 16th August 2006, 10:12 PM   #21
no, you aren't getting 675 ips. you probably forgot the threads per inch of the lead screw. Lets says its 12 tpi, then you would be seeing 60ish IPS which is pretty good. I suspect loading or resonance will kick in somewhere.
philba is offline
Old 23rd August 2006, 11:01 PM   #22
Originally Posted by Matilda
...I added the 8 "Ultra Fast Avalanche Sinterglass Diodes" to the output/motor leads.
I also have the SR line pulled LOW(Active Mode-Sync Rec Occurs).
I have driver in similar configuration... with 8 diodes
http://www.2a.pl/~mark/cnc/a3977/ster3977-22-d.png
I'm using byv27....
but with 31dq10 is better... or 1n5822
I also kept the grounds isolated.
As in,
To the A3977 I have 5V & 24Volts going to the chip.
Pins 44,1,2 22,23,24 33,34,35 are connected to the 24V supply ground.
Pins 11,12,13 are connected to the 5V supply.
With the chip off the board, these two ground paths are isolated.
The chip connects them internally.
That was a tip from Allegro. It really helped minimize noise seen on the 5v and 24V supply lines while the motor was running.
my driver is work... with 3A... constantly with 2,8A (and BIG radiator)
but when motor in motion some faulty steps will accur ...
with smaller current too
probably... its problem with noise
my project description:
http://www.pminmo.com/phpBB/viewtopic.php?t=64
http://www.cnc.info.pl/viewtopic.php?t=1783
markcomp77 is offline
Old 27th August 2006, 03:44 AM   #23
Thats good stuff you have there.
You should try seperating the grounds at the Allegro.
Let the Allegro join the grounds internally.
Made a small difference for me.
Matilda is offline
Old 27th August 2006, 08:33 PM   #24
I make it...
for me too
now I will tray strait connection form STEP -> to A3977
Old 23rd September 2006, 04:24 PM   #25
A little update.
With a little help from the folks at Allegro, I found the best thing to do was adjusting the RC components while scoping current on one of the motor windings.
The default components for the RC fromAlllegro is 30K & 0.001uF.
By messing around I found that having a 10K & 0.01uF gave me the best run for my money. REF is set at 2.2V & PFD at 3.1V.
According to Allegro, the 10K & 0.01uF I have chosen are in range for RC values, but since my motor is a little big (10mH), it has all worked out.
Scoping. I was scoping motor windings with locked rotor.
Zoomed right in on flat portion of the STEP, and adjusted the PFD for expected sawtooth waveform.
Motors are back to being a little noisey. And thats because the end user had asked me to cranked up the torque. And as the formalua goes, I get 2.2V for the REF. As I turn down the ref, and thus lowering torque/holding power, the noise slowly dissapears.
My end user will have to determine what sort of torque he wants....and put up with the noise.
I believe we may solve this audible noise problem by giving away a free radio with every purchase!
Matilda is offline
Old 23rd September 2006, 08:59 PM   #26
Remember, the noise isn't a bug... It's a feature!
phalanx is offline
Old 23rd September 2006, 11:22 PM   #27
Rt=10k & Ct=0.01uF=10nF => Tblank = 14us & Toff=100us
in datasheet
0.7us < Tblank < 1.2us
30us < Toff < 46us
Old 24th September 2006, 01:51 AM   #28
MarkComp77,
I've taken a screen shot of my engineering report for the project binder.
Here you will see I have scoped a motor winding.
Rotor locked.1/8" step.
Your looking at a step.
Motor is 10mH..
Matilda is offline
Old 24th September 2006, 02:55 AM   #29
It IS! There've been a couple of times where the existance/absense of that barely audible, high-pitched hum has made me stop, think for a second, and take a second glance at the cutoff switch - just in time to prevent me from doing something stupid...
hjames is offline
Old 25th September 2006, 11:13 AM   #30
MarkComp77,
Motor is 10mH..
on yours "Attached"...
Originally Posted by Attachment
1) PFD=3.1V 10A 100us
2) PFD=1.4V 10A 100us
??10A??
is It current of A3977 ?
PFD=3.1V
in datasheed =>
mixed decay
0.21Vdd > PFD > 0.6Vdd
and if Vdd=5V =>
1.05V > PFD > 6V
i use 2V...
but if you select PFD=3.1 => slow-decay
small question:
stepper with BIG inductance (10mH)
need bigger Tblank => bigger Ct ?
i use stepper with 3.6mH....
http://www.2a.pl/~mark/cnc/4a2.jpg
a3977, allegro, idle, noise
