Old 27th April 2006, 05:37 PM   #1
Default Need C code for HM55B compass of Parallax
I am working on HM55B compass but there is only a Basic sample code on the website of Parallax. Any guys used the device with AVR, especially, ATMEGA128 for robots or other applications? Can you share C code with me?
Thanks!
Learning by doing.
odense is offline
Old 6th May 2006, 07:13 AM   #2
Default Hm55b
Thanks!
I also need some info in this regard,
John.
mmsya is offline
Old 6th May 2006, 09:26 AM   #3
Surely it's trivial to convert the BASIC code to C?, if you can't I suggest you read the datasheet and write the code from scratch.
Nigel Goodwin is online now
Old 7th May 2006, 03:01 AM   #4
Default Hm55b
Hi Nigel,
Do we need to calibrate this chip or it is already calibrated in the factory? If we we calibrate what are we calibrating. Finding the max and min? I am a bit lost in this regard. I appreciate your help.
Thanks,
John.
mmsya is offline
Old 7th May 2006, 11:10 AM   #5
Originally Posted by mmsya
Hi Nigel,
No idea, presumably the datasheet explains it?.
Old 7th February 2007, 10:28 PM   #6
I just posted an inquiry on the HM55B together with a URL for information. One doc I downloaded shows a flow chart which should help in PIC code development.
I'm looking for PIC code or experience with the module.
The URL gives some links to other info sources. There is some setup required but I didn't fully understand it. They use the term brad (binary radian). Best I can determine a brad = 1.4 degrees (8 bit resolution of 360 degrees).
Try: http://info.hobbyengineering.com/specs/PX-29123.pdf
Also try: http://www.parallax.com/detail.asp?product_id=29123 multiple info links
Jess
jess is offline
code, compass, hm55b, parallax
