Old 10th March 2006, 10:28 PM   (permalink)
Default Motor Driver Relay Circuit
Hi all,
I have a serious problem. I am working on a robot. I use small and big motors for various things. I am using a relay circuit for driving motors, that's in addition to the microcontroller of course. I am using separate power supplies for each of the microcontroller and the motor. The microcontroller keeps on reseting !! and its vcc keeps jumping !!
That's in the case of using big motors of high current while in case of using the small motors with the relay circuit, everything is OK !!!
I tried using a buffer and I tried changing the switching transistors but it keeps reseting. Does anyone know what could be the problem ? I am using AT90S8515
acer_7 is offline
Old 11th March 2006, 08:51 AM   (permalink)
if possible use opto isolator. also do you have diodes connected to the relays the "wrong way"? relays are also creating big "sparks" when opened/closed. the diode must be from GND to Vcc cause relay creates those pulses the wrong way and then the spark wont get further than the diode so all is oke. the diode could be 1N4007
Need Help?
Press F1
If that doesn\'t help you, ask me... I might know better.
bloody-orc is offline
Old 11th March 2006, 12:54 PM   (permalink)
Thx for ur reply, what's an optoisolater
acer_7 is offline
Old 11th March 2006, 01:10 PM   (permalink)
opto isolator. optical isolator. a IC that has a Led and a phototransistor in it.
Need Help?
Press F1
Old 17th March 2006, 10:55 PM   (permalink)
Thanks it worked just fine
acer_7 is offline
