Old 4th March 2006, 04:43 PM   (permalink)
Default Right angle turn in line follower
I wish to contruct a line follower robot capable of performing 90 degree turns...So if anyone has any idea of how to do it please share them...
I am using a microcontroller,visible LED sensors and H-bridge driver IC...
[/b]
ppppking04 is offline
Old 5th March 2006, 12:25 AM   (permalink)
We have a line following competition that has only 45, 90, and 135 degree turns. See the rules at:
http://www.sciencecentral.org/2006ru...ne%20Following
The 45 degree turns are taked normaly. For the 90 and 135 degree turns, let the robot run beyond the turn, remember where the last line was (right side or left side) and turn in that direction to re-acquire the line. Here is a video of my run a year ago.
http://brooksbots.com/Movies/NEIRG%2...essway%20b.wmv
Rick Brooks
Rick Brooks is offline
Old 5th March 2006, 04:01 PM   (permalink)
what is a block diagram represntation of line follower robot kindly tell me.
High and high
hiyan is offline
Old 4th June 2006, 01:01 AM   (permalink)
http://www.geocities.com/njbibin/rob...efollower.html
a simple line follower
bibinjohn is offline
Old 29th July 2006, 09:01 PM   (permalink)
http://booksbybibin.14.forumer.com/viewtopic.php?t=125
Old 30th July 2006, 01:37 AM   (permalink)
I had to do that for a class (but with no microcontroller) and here's how I did it: Put two line sensors on either side of the robot, in the front. Space them so they are outside the line on either side (so they don't see the line). Then, when one sees the line, you know you need to turn.
Assuming your robot uses differential steering (i.e. steering like a tank), notice that, when turning right, the front-right corner will move right, in sort of a circle. So, when the robot's right sensor sees a line, you have it stop the right wheel(s) and keep moving forward with the left ones. It will turn right, and as it does, the front-right sensor will be sliding to the right. Eventually, it won't see the line anymore, and then you turn the right wheels back on. In other words, each side's wheels only get power if the sensor on that side doesn't see a line. That is a really quick and dirty way to do it (we only had logic gates for that class, no microcontrollers), and you have to tune things to make it work reliably. And of course the robot stops if both sensors see a line.
dreadengineer is offline
