Having problems with creating a LF program for my bot. I got an example from the net (Linbot) and tried to modify it to work for me. But I'm using 3 sensors instead of 4 so I'm guessing there's something about SENSOR_REG that I have missed or overlooked. Probably wrong bits or something... Any ideas? Code: CLRF SENSOR_REG MOVF L_AD_REG,W SUBWF VR_AD_REG,W BTFSC STATUS,C BSF SENSOR_REG,0 MOVF C_AD_REG,W SUBWF VR_AD_REG,W BTFSC STATUS,C BSF SENSOR_REG,1 MOVF R_AD_REG,W SUBWF VR_AD_REG,W BTFSC STATUS,C BSF SENSOR_REG,2 MOVLW B'00000111' ANDWF SENSOR_REG,W ADDWF PCL GOTO NO_LINE GOTO LEFT_LINE GOTO CENTER_LINE GOTO LEFT_CENTER_LINE GOTO RIGHT_LINE GOTO NUL_LINE GOTO RIGHT_CENTER_LINE GOTO CENTER_LINE
__________________ Here...let me improve it for you! *Puff of smoke* ....oops... | |
does the program compile?
__________________ when you post that reply, im just kidding. | |
compiles fine and even works when covering left sensor. And would like to post another question without making a new topic... how do I change first 4 or last 4 bits of a port? Controlling two stepper motors with PORTB and would like to give the steppers different speeds via changing the pause between steps. That means I need to change one motor status without touching the other... can't figure this out...
| follower, line, program |
