I desperately need compact (and affordable) gear boxes to build a 4-legged walker.
size should be 1.5 in x 1.5in MAX. (or something close) I guess I could use servos, but due to my budget, I simply cannot get 8~12 servos. (The cost adds up quickly). Is there any way to obtain cheap, small gear boxes? I am not looking for high quality, metal, gear boxes, but just some plastic ones. I have heard of gearboxes modified from Oven Timer Unit (OTU), but I can't get hold of OTU's..... Is there a way to build gear boxes....? |
Have you tried an electronics hobby shop in your area? Perhaps they even have a catalogue where you can order on the net. Here in Australia they have small DC motors with attachable gear boxes advertised. Several types of gearboxes are available, eg. spur gear, planetary gear and worm gear. They have small low torque plastic parts and are inexpensive.
Klaus Quote:
Hm...I found some gear boxes at stores (not really cheap)
Just one question. One gear box says it is "29 RPM" Does that mean its max rpm is 29? |
Ususlly gearboxes have a ratio given, like 100:1 or whatever. The price range of these kit gearboxes here is from $AUS15.- for a simple worm gear to $AUS30.- for a planetary box, including the motor. These are a 'TAMIYA' brand. While scavaenged gearboxes and motors often cost you nothing, you are then faced with making small couplings to join them. Easy if you have a hobbyists lathe, tricky or expensive otherwise. You also need some metal bashing skills to mount these as odd scavenged items rarely bolt straight together. Klaus |
For really cheap gearmotors: www.solarbotics.com
For a different reason I've searched, few days ago for "spur gears" and Google vomited tons of data. They looked expensive, but... :?:
Agustín Tomás In theory, there is no difference between theory and practice. In practice, however, there is. |
What about buying a cheap plastic tanks (kit). The motorized ones comes with a complete 2 motor gearbox setup. TOK |
You could try converting a servo to full 360 operation. There are some guides on the net. Just google it.
www.winpicprog.co.uk - Great PIC language tutorials. |
I have 10 identical GWS MINI servos I will sell you very cheap or trade for ?
Only a few of them have actually been used, but not very much. They are a bit smaller than what you need, should do fine. Heres a link to the on GWS site http://www.gwsus.com/english/product/servo/mini.htm |
Eh mate I'm interested in those mini servos so send me a P.M. if your interested in selling them Cheers Bryan
" The only way to avoid human error is to avoid the use of humans" |
You got PM bryan
