this question i not realy on robots. but i am planning on making a pc parralel port controlled robot or "car" im only going to use 1 data line. i can program ok, i can output anything to that "one" line. can anyone help decoding that message. it will be in binary. also what message should i use. should i use "f1" for forward 1? thanks
__________________ when you post that reply, im just kidding. | |
| | #2 | ||
How about having the first 3 bits determine the comand and the 5 bits to give the comand data that it needs. And you can send it in only one byte.You cod also make it first byte the comand and the second byte data.(but what the heck wod you fo whith 256 comands)
i was thinking about 1 line i think i could work im using the parralel port because it is much easyer to program in my opinon. what i mite do is this, use a 4017 counter then a 555 timer to give a break then data will be directed pass it all
| robot |
