Old 7th July 2005, 06:27 AM   (permalink)
Default JDM Programmer
Hi I want to make a line follower robot.But I have a problem to write
the program into the microcontroller AT89C2051.I need a JDM programmer.Do u hav any JDM programmer that is easy to build on my own?Please give me the schematic as well as the components details.
I refer to this line follower robot website.
http://www.kmitl.ac.th/~kswichit/LFrobot/LFrobot.htm
ThanX.
AreZamy is offline
Old 7th July 2005, 06:38 AM   (permalink)
Sorry about this so ashamed question.I actually can't understand this circuit.I'm a newbie dude!
AreZamy is offline
Old 7th July 2005, 06:46 AM   (permalink)
Hiya Arezamy,
The 10 volts you circled near the battery is actually the battery voltage which feeds into a 5 volt regulator to give you 5 volts for the processor and the 10 volt rail is the supply for the motors. The L293 has been replaced by the sn755410ne chip from TI which can handle 1 amp of motor current as the L293 can only handle 500 milliamps. If you read up on the datasheet it tells you everything you need to know.
Hope this helps
Oh and as for the programmer do a search as there a heap of circuits out there including this forum
Cheers Bryan
bryan1 is offline
Old 7th July 2005, 10:11 AM   (permalink)
Try this: http://www.jdm.homepage.dk/newpic.htm
"I share, thus I am"
Jay.slovak
Read this!
ICD2 Clone
Best PIC/DsPIC Bootloader
Read my Inchworm ICD2 review!
Jay.slovak is offline
Old 7th July 2005, 11:16 AM   (permalink)
Originally Posted by Jay.slovak
The page cannot be found
AreZamy is offline
Old 7th July 2005, 11:24 AM   (permalink)
Strange, that site used to work....
Try this: http://www.olimex.com/dev/index.html
Jay.slovak
Read this!
ICD2 Clone
Old 7th July 2005, 04:46 PM   (permalink)
A JDM programmer will not work in your case. You need to use a parallel-type programmer in order to program the At89C2051, which needs 8-bit of data all at once to program a single byte.
The schematics of a suitable programmer is here:
Schematic of TAFE Programmer
You can use the ICProg software to sent the hex file to the 89c2051.
L.Chung
eblc1388 is offline
Old 8th July 2005, 08:15 AM   (permalink)
ThanX I really appreciate your help.
______________________________________
NewbiE Learn From Other Experience
('c',)
AreZamy is offline
