Old 2nd July 2005, 02:32 PM   (permalink)
Default What do i need to know to make a good robot?
I want to design my own robot.
I study Computer/Electrical engineering.
I have a wide knowledge in programming languages like C++ VC++ and VB.
I also have good knowledge in dealing computer ports, semi-conductors, electrical ciruit synthisis and embedded systems using PIC microcontrollers.
What else do i need to know about?
subzero... wins..
sonaiko is offline
Old 2nd July 2005, 09:18 PM   (permalink)
It's sort of hard to say. Since you already have PICs, I'd check out motor-control applications that use PWM and also read through Microchip's app notes to learn to make the most of your PIC interrupts. I pile of extra 74** and 40** series chips doesn't hurt either.
A/D conversion for your sensors is a must. Analog devices like comparitors get downplayed a lot now because those functions are often integrated into the controller itself, but its good to keep a few op-amp references on-hand. Motor control can be done using H-bridges while a Pulse Width Modulated signal controls the speed. A more compact method is to simply purchase a motor control IC. The ICs are also good for servos and stepper motors, which require specialized.
There are really too many subjects to cover in one post. Probably the best way to get started is to search for every bot project you can that has used a PIC controller. Besides our own forum here, two sites I recommend are Dallas Personal Robotics and Seattle Robotics' "Global Encoder". In addition to being a good parts distributer, Digikey.com has a good parts search feature that will give you datasheets and prices.
The most-hated young engineer in America.
* AVR Projects
* Robot War: TI
* About
DigiTan is offline
Old 3rd July 2005, 01:47 AM   (permalink)
Default Re: What do i need to know to make a good robot?
You should be able to program a microcontroller and based on the program, the robot does various things. You also need to be able to convert a digital signal to a motor voltage. For example, if there is a logic "1" output, then the motor stays on. If there is a logic "0" output, the motor stays off.
-=: The best low-priced components to troubleshoot with are the speaker and the LED :=-
mstechca is offline
Old 3rd July 2005, 02:49 AM   (permalink)
Study Biology or entomology to be specific , I know it seems a bit odd but many of the challenges of robotics have allready been solved by mother nature.
Consider a simple insect such as an ant.
Six legged all terain locomotion , simple compound eyes, able to navigate using the sun,touch and scent trails, a single manipulator yet able to lift over ten times it's bodywieght, able to work alone or in concert with others to achieve a goal
It may seem like a good idea at the time but.. never stir your cold coffee with a soldering iron.
tansis is offline
Old 3rd July 2005, 03:35 AM   (permalink)
You might want to try one of the robot kits first, to get an understanding of what goes into a robot. It can be a little intimidating to start from scratch.
This is a good kit and there's a Yahoo group to support it:
http://www.junun.org/MarkIII/Store.jsp
Mike
upand_at_them is offline
Old 4th July 2005, 06:09 AM   (permalink)
HI i'm a newbie here
AreZamy is offline
