| I have read some threads about programming Serial/parallel ports. And I just Want to ask about the most popular programming language is used to communicate with Serial/parallel ports. I have started learning Borland Delphi 7few days ago. I was told that it's the most suitable for purposes like these. Would some one please tell If this is the best choice for me. I have finished my school and this is my mission for 2.5 months. In order to make communication between my PC and my PICs. Any advice will be appreciated | |
| in my opinion borland Delphi is an good choice for controlling the serial & parallel ports , because i understand that it is very similar to Pascal , which is an excellent language to learn.. | |
You should be aware though that any NT based Windows (NT, 2000, XP) doesn't allow direct access to the ports, you need to access them through a driver - this applies to ANY language running under Windows NT. | ||
| | (permalink) | ||
There is a programming language called Visual Basic. May be it is a best choice for beginner. Visit website below to read more about VB, http://www.geocities.com/bagtool/serial_basic.html http://www.geocities.com/bagtool/parallel_basic.html free | |||
| quickbasic is the best. It is the same as VB except that there are no predefined objects, and it is suited for 16-bit systems. It works under all versions of windows (at least up to 98). Quickbasic has built-in serial port functions. you can download a free copy from Microsoft. Just do a search for the file olddos.exe
__________________ -=: The best low-priced components to troubleshoot with are the speaker and the LED :=- | |
| | (permalink) | ||
Anyhow, MS in their wisdom wanted to 'regulate' the use of the serial ports so it knew what was going on. This meant it needed to stop low level access to applications and 'force' the use of dll's of which there are many commercial and free ones. I use NETcommOCX which is a 'wrapper' for the MScomm dll from MS. MSComm was part of Visual Studio up until version 6, since then its not been included and can only be used if older versions are also installed to register the controll properly. Now, linux is the way to go! lol. haha. | |||
| | (permalink) | |||
As a matter of interest I once ordered QuickBasic 4.5 for a programming job I did, on an Amstrad XT, running 5.25 inch floppies. I'd written the original program using Amiga BASIC on the Comodore Amiga, but the customer then wanted it porting to the Amstrad. | ||||
| If you already know a form of Basic, VB is a good choice, but will take some study just to figure out how to get started. Once you get that, you can port some of your already written basic code inside the forms, without serious modification (except your event traps) Higher level Windows functions not available in earlier basic versions can also be used via API calls (millisecond accuracy timing and such) and the serial parallel port manipulations also can be API programming calls to freely available pseudo-drivers such as InpOut32.dll. There are versions that even run under the Windows NT variants. Dialtone | |
| Thank you very much guys for your responds I want to make programs which are visual and I already have a back ground in Pascal and C++. And I found it the shortest way for me to start with Borland Delphi 7. BTW, What about Borland C++ Builder? Any one has experience with this environment? | |
