They will transmit variable width pulses, again though, within the constraints of their AC coupling - you would need to experiment. The more expensive ones come 'ready to use', with a pre-programmed PIC doing all the work for you. |
go to www.rentron.com
they have a transmiter/reciever that connects to a computer the total cost for both would be 120 to 130usd not bad at all. Plus free software.
Robotics is heaven in my book. |
I found very good transmiter and reciver on site: www.linxtechnologies.com Price very low. |
Ya but it is easier to interface with the computer using the rentron tx/rx even though they contain parts from linx.
It all depends on time wise.
ok well i chose SC-P tranciever module from linxtechnologies.com
is it any good? is it "smart" (inside coding) what and when do i send to it? can i communicate wit it via i2c? or serout?
Need Help? Press F1 If that doesn\'t help you, ask me... I might know better. |
You simply use a serial connection, I2C isn't relevent to this type of system. |
ok i red the data and seems wery good
i think i will get that for my birghday if i do the exams OK
You can design a RAM7 board and burn Linux kernel into it.
1) Linux Kernel support some webcam such as Webcam of Ov511 chip 2)You can also cross compile an Open Source Video Server for RAM, The Video server have ability to send your video which is captured by your webcam to Upper computer 3) you can cross compile an USB Wi-fi driver for ARM Last edited by bingbinICE; 13th August 2007 at 10:48 AM. |
For simpler, You can chose a Wireless USB hub for your goal. Ultra-Wideband (UWB)Wireless Hub is a new technology of USB interface thch.
you can get more info from: http://www.yedata.com/news/image/060829.pdf Saitama, Japan, August, 29, 2006 -- Y-E DATA, Inc. (Headquarters: 182 Shinkoh, Irumashi, Saitama, representative director president, Mr.Kaneyuki Hamada) announced the development of ‘ UWB Wireless Hub, YD-300 ‘, in collaboration with Wisair. The ‘UWB Wireless Hub, YD-300 ’ will be available for the market in October, 2006. The YD-300 consists of a host-dongle and a wireless hub with 4 USB ports. It provides the wireless transmission of data between a PC and existing wired USB devices such as HDD, DVD, mouse, keyboard, printer, digital camera and so on. The YD-300, by eliminating cables, frees up space around the PC with wireless technology and ensures a comfortable environment for PC users. In addition, this solution enables a wireless portreplicater with ease for notebook-type PC. Key Features Up to 480 Mbps air data rates Up to 10 meters operating distance Compatible with Windows XP 4 USB port hub Host Dongle: 29.8(W), 96.2(D), 9.4(H) mm Hub: 103(W), 79.5(D), 19(H) mm NewsRelease Y-E Data Inc. 182 Shinkou Iruma Saitama Japan In the near future, Y-E DATA will provide solutions with the ‘Certified Wireless USB’ technology of USB Implementers Forum, Inc., as well as PCI Express interface solutions. These will include, for instance, an ExpressCard/34 host card and PCI Express Mini Card, to expand the possibilities of wireless technology. |
sorry, I'm late to the party!
The goal - transmit video wireless from robot to remote laptop? The solution - 802.11b camera: http://www.trendnet.com/en/products/TV-IP100W.htm that one is about "middle of the road" for features and pricing. you'll need 802.11b/g on your laptop, and will probably need to setup the camera via wired connection first, but then it should stay configured, ready to go on adventures with the robot. it only needs 5vdc, which any good microcontroller powered robot should have in abundance right? the thing to look for if you decide to purchase on of these - make sure it supports ADHOC networking, so you don't have to lug along a wireless access point if you go out in the field. I like this model because it has an external antenna, which you can replace with something more powerful. EDIT: oh, just re-read the original message, you want RX and TX ... well, sending video is a lot harder than sending telemetry. Does your laptop have bluetooth? You could use a bluetooth serial module to carry the telemetry, or any of the other small serial data radio modules. Even 9600 baud can carry a lot of data. If your hacking skills are good, you might be able to tap into the camera's software and processor some how. The wifi camera's processor probably has some sort of uart interface in it - exposing the correct pins should be a matter of some data sheet digging, exposing it in software will be the challenge. Others may have hacked a wifi camera already, laying the groundwork for you.
If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 Last edited by justDIY; 13th August 2007 at 01:27 PM. |
This thread is 30 months old!!
Mike. |
oh my, well not too relevant anymore I suppose
guess I didn't notice the time stamp on the original posts, just the latest posts from the newbies.
If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 |
Threads from the crypt.
I often read the ancient threads and when the reality/complexity/cost of the project becomes clear... Poof end of thread. |
this thread is 2 old.....u can do tthis wid a wifi and bluetooth in ur system wid a bit of programming...
