Old 19th February 2005, 10:14 AM   (permalink)
Default better motor braking
hi, i know the method comonly used to brake DC motors is to short the windings.
But in my application i need to pull objects to a certain height with a very simple system consisting of a mottor turning a wire around its shaft and the object is attached to the other end of the wire, i hope you see what i mean.
If i use this classical way of braking i think it wont overcome the weight of the object being pulled.
So, wouldn't i get much better bracking if i keep inversing the current in the winding (Fwd-Reverse) at a relatively high frequency? in such way that the motor doesen't have time to response or move according to any of the 2 currents, but in the same way it would be kind of being braked by a foce as strong as the one that raised it..
is this theory true?
if so, what frequency would be suitable..?
thx a lot
Ibrahim Kamal
check my electronics and robotics page: http://www.ikalogic.com/
ikalogic is offline
Old 19th February 2005, 10:50 AM   (permalink)
Default Re: better motor braking
It would probably have some kind of 'locking' effect, but it's highly likely to destroy the motor through over heating. I would suggest you use a worm gear from the motor, this will greatly improve it's resistance to movement from the load, even without braking - plus give you much greater torque.
Old 21st February 2005, 07:46 AM   (permalink)
Further to Nigel's suggestion, a mechanical brake is often used too. You'll find small band type brakes inside every cassette tape recorder or in the older VCR machines. Another way is external brake shoes around a narrow drum on the shaft, this system is used on lift motors.
the mechanical brakes are solenoid activated.
Klaus
Klaus is offline
