| hi i want to make a line follower with pic16f84... i use photodiodes for detecting the line... but i d'ont understand how can i capture with the pic the voltage that came out from the photodiodes... can you explain it to me? tnx | |
| You may have to uas an Analog to Digital converter converter as the F84 doesnt have one , but other inexpensive models do have an A/D converter.. | |
However, for line following you can easily do without analogue inputs, use comparators to generate a switching signal from the photodiodes, you can make the other input of the comparator adjustable so you get a reliable switching signal from the line detection. If you use the 16F628 (the 84's direct replacement), it already has internal comparators, and an analogue output for use with the comparators. | ||
| can you tell me some comparators that work for line follower? | |
| i bought today a LM2901 comparator... and it works.... but the output voltage is not the V+, it is <1V why? | |
| comparators typically have open-drain outputs. that is, for a low output, they pull it to ground normally, but for a high output, they act as an open-circuit. you need to use a pull-up resistor with it most likely. | |
| so i have to put a 4k7 resistor from 5v to output? | |
| Eh UnD3aD, It looks like you haven't had much to do with opamps or the like here is a link to some tutorials, I find them very informative and I always refer back to them when I don't know where to go next in my designs http://www.uoguelph.ca/~antoon/index.htm Cheers Bryan1 | |
| http://cache.national.com/ds/LM/LM139.pdf check out the Typical applications pages 7 - 15.. | |
| it's working.. not for that scheme | |
