Originally Posted by AndyNDQ Please help, I tried to drive a 9V DC motor using the 2N2222 NPN transistor, but the transistor got burn (probably overpowered). I connected the motor in series with the emmiter, with 9V the going to both the base and collector. Someone had suggest that I connect a diode parallel with the motor, but I got a reading about 0.7 V across the motor, that won't drive the motor. Is the a circuit I can build to drive the motor? |
You should have the motor in the collector of the transistor, with the emitter going to 0V. The base should be fed via a resistor from whatever is doing the switching. It's essential to fit a reverse connected diode across the motor, or the back emf will probably kill the transistor.
Try looking at the 'hardware extras' page in my tutorials, the bottom diagram shows how it's done for a relay or motor.
