Old 12th October 2004, 01:37 AM   (permalink)
Default help with gps robot
hi, i need help, i am building a gps controlled robot. the aim is to build a robot that can automatically find fixed locations (without a remote control) using information it gets from an on board GPS. could anyone that know anyway i can go about it pls leave a message for me.
thanks
muhtar is offline
Old 15th October 2004, 05:51 PM   (permalink)
First thing...... how accurate does the system need to be?
// GreenGrove
GreenGrove is offline
Old 22nd October 2004, 01:52 PM   (permalink)
very accurate, cos it will be used over a long distance. thus a small error will cause loads of problems for the robot. most of the navigation will be software based so hopefully if i get my calculations right it should work. but will appreciate it i can find other ways of achiving the same aim.
muhtar is offline
Old 22nd October 2004, 02:41 PM   (permalink)
Most relativly cheap GPS units are only accurate within 10 ft, and the signal can be erratic at times, depending on tree cover clouds ect.
What is the robot going to do when it gets to this area? and what kind of terrain is it going to be on? A few more details aobut the purpose ect would be very helpful
Jeff Zimmerman
jrz126 is offline
Old 25th October 2004, 01:59 PM   (permalink)
The sort of GPS you need for this would be dGPS, that can have accuracy down to less then 5 mm whilst in proper conditions. Perhaps...if you vehicle is about to be in one specific area you might think of positioning by LAN.
// GreenGrove
Old 29th October 2004, 12:54 PM   (permalink)
well, im using a very cheap GPS for now. the Robot will work on not too rough grounds and in the initial stage im assuming perfect conditions.
im now stuck on the relationship between longitude,latitude and angles between two points. ie. if i know the long and lat of two points how will i get the angle between them. i think the haversine formula explains it but i dont really understand it.
muhtar is offline
Old 1st November 2004, 10:11 AM   (permalink)
I have some scripts there that will convert lat long into ordinary xy-coordinats. If you send me an email at greengrove[at]email.com i can send them to you.
// GreenGrove
Old 5th November 2004, 04:09 PM   (permalink)
Default -
Well, I also got a GPS robot. But the control script got incrypted. So i had to spend about $10,000 to hire a professional who hired a bum off the street who oddly knew how to fix a GPS robot. Any way the control script actually was in the wrong place and I spelt left wrong. So when used it, there was no "Left" So i called up the bum again. He found the problem and I finally got my GPS robot back. They i left it running for 5 weeks and it blew up.
YO BOYEES, IM YOUR BOYEE. REPRESENT.
l337 8oY is offline
Old 9th November 2004, 03:57 PM   (permalink)
Default I did too
I also spent 10000 dollars on repairing my GPS robot. But my bum was a better trained technician. He had some skills, but he handled the robot poorly. After he said that he was "finished", it turned out that the robot was in worse shape than that of when he got it. I wasted my $10000 by hiring a bum on the street to do my repairs. I will never do that again.
By the way...you suck, boyee
gurgalesci is offline
Old 9th November 2004, 04:25 PM   (permalink)
man , this thread went to hell :lol:
williB is offline
Old 12th November 2004, 05:09 AM   (permalink)
I don't know if this is the size is what you had in mind, but I purchased a Trimble SV6 GPS receiver (passive antenna included) about 2 years ago for 20 U.S.D. I haven't gotten to experiment with it much beyond downloading some software timestamp software, but there are few useful walkthroughs on the web; including this one. There doesn't seem to be many left, so prices appear to be fixed around $25 in the US.
DigiTan is offline
