would it be possible to store the energy from the reverse EMF of a stepper, as it is running.
i was just wondering if i could save power in battery powered robot with a very large electrolytic capacitor connected across the main power supply. |
To make the system effective, you will have to get that energy back into the battery. When the vehicle is moving but the drive is not driving the motors, the motors can act like generators and that energy can be recovered but it is more complicated than just using a capacitor. |
ok but when u turn off a coil in the stepper,, and redirect the back EMF with diodes twards the positive supply terminal,, where does it go..
i can only assume that it is stored in the powersupply caps.. so that is what i had in mind with the battery setup.. |
Ive just got my robot moving for the first time..last night..
i am using two steppers ,one for each back wheel. the two steppers are connected together..ie driven by the same drive transistors..i will drive them seperately after i get four more IRF 510's i realized thet i had to run the second one in reverse so i made the proper connections something very strange happened .. When all power was off and i turned one wheel ..the other wheel turned in the same direction..!! so i turned it the other way .. the other wheel turned in the other direction!!...hmm..sort of an electronic mini car differential |
i had a neighbor that called a flashlight a torch.
over here , a torch is what the croud was using to find Frankenstein at night.. :shock: :wink: :wink: |
(permalink) | ||
(permalink) | ||
Nigel looky what i found while roaming around the net..
what i found particularly interresting was the Pic net USB page http://www.alecmcnamara.freeserve.co...tusb/index.htm could not an ambitious person devise a USB pic programmer with this info?? |
Basically both the PICKit 1 and the PIC Net design use the code from the original 745 application note. |
I thought that i would show yall my robot car .
this board takes the signals from the PC .. later on from the Pic..
and drives the steppers.. |
