| HEy all.... i want to ask about the IR detector(LED and photodiode)...!!! how far can it be??? can be around 10cm???? If not.... wat should i do??? is that necessay i use the powerful detector like panasnic one?? erm...!!! i so blur now..~` hope someon :? e can help me | |
| have you got a circuit in mind? An IR emitter can work many meters.. try this .. get a TV remote .. set a port pin for input . hook up detector output to port pin input ..( the detector should output a series of 0 to 5V pulses). point remote at detector if your pic has analog input even better.. hook up the detector output to analog input and see waveform of the remote ( they are all different ) | |
| ic.... but how about i don;t want too far... erm... got a certian distance.. like 15cm only..??... if that possible i set the distance for the IR pair?? act i got the detector already,.. its a panasonic branded .. from data sheet.. it shows that it only 3m max.. :roll: | |
| Over longer range, you need to send pulses and detect the change in the receiver, otherwise ambient light will trigger it. Ambient light usually doesn't interfere with a short range thing because the signal strength at 1 cm is so much higher. IR with a packet of pulses is used for laser tag & military game guns, those range at least 100s of feet. | |
