| I am doing my robot programming, it supposes to turn left, stop, and turn right, but now it just make turns, I can't figure out, anyone can take look at my programming, thank u for reading , I really appreciate..... int RIGHT_MOTOR= 0; int LEFT_MOTOR = 2; int LEFT_BUMPER=7; int RIGHT_BUMPER=9; #define TURE 1 #define FALSE 0 #define FORWARD 1 #define REVERSE 2 #define TURN_LEFT 3 #define TURN_RIGHT 4 #define STOP 5 persistent int ix; void main() { while(1) { printf("Press start\n"); if (start_button()) { while (!stop_button()) { motor_routine(FORWARD); if (digital(7)) { motor_routine(STOP); sleep(0.25); motor_routine(REVERSE); sleep(0.25); motor_routine(TURN_RIGHT); } if (digital(9)) { motor_routine(STOP); sleep(.2); motor_routine (REVERSE); sleep(0.2); motor_routine(TURN_LEFT); sleep(.2); } } } } } void motor_routine( int motor_cmd) { if( motor_cmd==FORWARD) { fd(RIGHT_MOTOR); fd(LEFT_MOTOR); } if( motor_cmd==REVERSE) { bk(RIGHT_MOTOR); bk(LEFT_MOTOR); } if( motor_cmd==TURN_RIGHT) { ao(); motor(RIGHT_MOTOR,45); } if( motor_cmd==TURN_LEFT) { ao(); motor(LEFT_MOTOR,45); } if (motor_cmd==STOP) { ao(); } } | |
| this is my project: Building the basic robot In this exercise we will build a robot with the most basic behavior, escaping whenever it hits something with its bumpers. Perform the following programming steps: 1. Upon pushing the START button, the robot moves forward and stops after the STOP button is pushed. If a bumper switch is activated: 2. Backup a quarter of the length of your robot using the IC time commands, storing any constants set as persistent global variables for use in later programming (see page 12 of the Handy Board manual or page 408 of your text). 3. Turn 45 in the opposite direction of the bumper switch activated (i.e., turn right if the left bumper switch was engaged) and then continue forward. Use the attached outline for your code. // ECE 450: Bumper Car Lab // Team # // Names? /*Port Definitions */ #define RIGHT_MOTOR 0 /* Motor Slot 0 */ #define LEFT_MOTOR 2 /* Motor Slot 2 */ /* Logic */ #define TRUE 1 #define FALSE 0 /* Motor Commands */ #define FORWARD 1 #define REVERSE 2 #define TURN_LEFT 3 #define TURN_RIGHT 4 #define STOP 5 /* Persistent variables */ persistent int ix; void main() { while(TRUE)//infinite loop { Print ¡°Press Start¡± to the LCD Screen Wait for the start button to be pressed If Start Button is pressed { While The Stop Button isn¡¯t pressed { Move Forward If Left Bumper is pressed { Stop Backup 1/4 length of robot Turn Right 45 degrees } If Right Bumper is pressed { Stop Backup 1/4 length of robot Turn Left 45 degrees } } Stop Button was pressed so STOP } } } //end of main routine void motor_routine(int motor_cmd) // Defines motor actions { If (motor_cmd == FORWARD) Set Right and Left motors to go forwards If (motor_cmd == REVERSE) Set Right and Left motors to go backwards If (motor_cmd == TURN_RIGHT) Set Right and Left motors so robot turns right If (motor_cmd == TURN_LEFT) Set Right and Left motors so robot turns left If (motor_cmd == STOP) Stop! }//end of motor_routine definition | |
| Firstly please indicate whether the project is for c programming or for a robot only then can some help be provided. | |
