Originally Posted by indie Does anyone here know about the principle of electronic control in servo motor work ? I mean about the electronic circuit there ? How do they work? Because I think the problem comes from that part...  |
Servo's a generic term that can mean lots of things, so I'm guessing you're talking about those 3-wire radio-control servo motors.
The circuitry inside is a bit complicated, but what it amounts to is the motor also drives a small potentiometer, and the circuit uses this potentiometer to tell where it is so it can move to where it's supposed to be. They've got three wires - power, ground, and signal. Power and ground are pretty self-explanatory, I think they need around 6v or so. The signal line takes 50Hz pulses, which should be between 1-2 milliseconds in length. 1 millisecond means all the way to the left, 2ms means all the way to the right.
If the circuitry in the servo itself is fried, you're probably out of luck, but if it's just a gear broken you might be able to get replacements from the manufacturer.
