Old 30th July 2004, 02:35 AM   (permalink)
Default micromouse sensor
I'm design micromouse sensors (topdown), as the maze is in black lines on white background (not walls).
Currently my circuit is very simple.
However, as my friend suggests I should filter out ambient light, and have no clue about it.
How should I do that filtering?
banh is offline
Old 30th July 2004, 03:15 AM   (permalink)
turn off infrered led
take your reading
turn on infrered
take reading2
reading2 - reading = no ambient
spindrah is offline
Old 30th July 2004, 06:52 AM   (permalink)
take your reading
turn on infrered
take reading2
Unfortunately that wouldn't work, the circuit only provides a high or low logic output.
You could try fitting an IR filter over the phototransistor, this will reduce visible light interference. But the best way is to modulate the IR LED, and detect the modulation after the phototransistor - which is how remote controls work, to avoid interference from ambient light.
Nigel Goodwin is online now
Old 30th July 2004, 07:06 AM   (permalink)
ok i didn't realy look at it
i was thinking of reading the photo trans with an A2D pin from the pic
if you are useing a pic that is an easy way to do it
thats what i use on my balanceing bot, to get the distance from the floor
but its also vary sensitive to color change
spindrah is offline
Old 30th July 2004, 07:13 AM   (permalink)
some suggest pulsing the infrared transmitter ( to save the power instead of always transmitting). Every time we enable the transmitter, wait for a while and read in from the receiver side. At the receiver put a high pass filter to filter out ambient light. I'm not sure how this works, and how to implement it.. Is it that for high pass filter just put a RC circuit ?
banh is offline
Old 31st July 2004, 02:09 PM   (permalink)
No, pulsing transmitter is not only to save pwr. It's to make a frequency filter. If you transmit all the time, and outdoor, you may get noises from sunlight, or other IR sources, heats... You transmit at high frequency, you will recieve the right signal. They used to use about 40KHz for IR tx and rx.
falleafd is offline
Old 1st August 2004, 06:11 AM   (permalink)
thanks
banh is offline
Old 27th August 2004, 11:08 AM   (permalink)
My connection is the same as above, but at the transmitter side, instead of connecting to GND, i connect to clock.
At the other side, I measure voltage before going through filter.
However as clock frequency increases, p-p voltage measured decreases, and only reach max 5V when about 1Khz clock. Waveform at receiver also is not square.
Any thing wrong with my circuit?
banh is offline
