Check the electrolytic capacitors in the PSU, you need an ESR meter to do this - often this is all that fails.
Hi Guys,
Thanks so far with the great advice. I have another question I was hoping someone might be able to help me out with.
My friend has a 42" Vizio LCD TV. He's had it for over a year. The warrenty is expired (go figure).
When you turn it on, all that is viewed is a bunch of colored horizontal lines flickering and dancing around all over the place. There is no sound, and no way to access the menu/change channels.
He brought it to Best Buy (where he got it from) and the geek squad looked at it and said it would cost more to repair it than a new one is worth.
I offered to find out as much as I could about the problem and possible solutions for him. I did take a sememster of electronics in college and a single class in HS, so I sort of know what I'm doing. I just dont have a place to start with this TV.
Any help would be greatly appreciated. Thanks Again!
Thanks Mr. Goodwin. I will have a look. By PSU you mean Power supply unit? I'm unsure if this one has an external power supply or if AC power cord is hooked durectly to the TV. I dont have the TV in front of me.
How would I go about checking capacitors? The only time I've ever dealt with them is when they have melted when transistors when out in other electronic equipment.
How could capicitors cause this screwy display output? (not providing enough voltage?)
Thanks!
Yes, capacitors in the power supply - even if there is an external unit, there is still an internal power supply as well.
You require an ESR meter to test them, although if you're lucky you may spot some with domed tops.
PSU problems can cause all kinds of strange effects.
Sorry, my elecronics knowledge isnt up to par (ESR Meter?)
I have a multimeter with all sorts of different settings, am I able to use that to test them with that?
Thanks!
Unless you can visually see a damaged component, without schematics and a fairly high level of electronics experience your chances of repair are slim to none.
well its a big waste of space as it is.
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| tv repair | johnny69 | General Electronics Chat | 16 | 1st February 2007, 10:20 AM |
| TV repair... | Marks256 | General Electronics Chat | 18 | 24th October 2006, 09:30 PM |
| Trying to repair a PCB | 2PAC Mafia | General Electronics Chat | 3 | 26th January 2005, 01:46 PM |
| How to repair UPS | ramon | General Electronics Chat | 2 | 9th November 2003, 02:31 PM |
| DMM repair | mp3hombre | Electronic Projects Design/Ideas/Reviews | 1 | 28th July 2003, 04:33 AM |
