Go Back   Electronic Circuits Projects Diagrams Free > Electronics Forums > Repairing Consumer Electronics
Repairing Consumer Electronics If you're trying to fix an electronics device like a TV, Stereo, etc you can discuss it here.
Old 11th November 2009, 06:00 AM   #1
Question Pioneer SX-205 Stereo Receiver does not power on...
Hi there folks. My name is Mike and I have recently purchased a Pioneer SX-205 Stereo Receiver that does not power on. I give it 120VAC and press the power button, and nothing happens. I have checked the fuses, and they are good. I get 70-80VAC output from the transformer. I'm not sure what component/s would be bad in order for this unit to not do anything? The only thing that happens when I press the power button is that I can hear a very faint high pitched tone from the main PCB. Very, very faint. Other than that, my desktop light dims a little from applying the load, but nothing else happens... I'm not sure what the transformer is supposed to supply on the output side, but it appears to be good. Any help would be greatly appreciated. I am somewhat new to electronics and am eager to learn all that I can!! Thanks for your time.
UPDATE: I did some more investigating on the main PCB and noticed three small diodes where underneath them the PCB was discolored as if it had been burnt. I removed these three diodes, labeled "A28" or "82A" and tested them, they show an ohm reading in one direction, but not the other, which I'm thinking means they are good? I also removed the small electrolytic capacitor and tested it, and it appears to be good... I'm not sure what these three diodes are used for, and I'm not sure if the PCB being burnt under them is a sign of anything but heat, but I thought I would add it here!
I'm still thoroughly confused by this receiver, and still cannot get it to power up. I get several different DC volt readings across the PCB in different areas... So I'm thinking that the rectifier is good?
I'm looking forward to anyone's input on this matter, It will be greatly appreciated!!
Thanks.
sirmikeylikesit is offline
Old 12th November 2009, 06:59 AM   #2
“We are more casual about qualifying the people we allow to act as advocates in the courtroom than we are about licensing electricians.”
pioneer, power, receiver, stereo, sx205
Onkyo stereo receiver poor output Megabit2k Repairing Consumer Electronics 2 4th August 2009 07:38 AM
A stereo FM receiver using the TEA5711 IC radiomate Electronic Projects Design/Ideas/Reviews 45 28th July 2009 12:19 PM
Looking for a 'mono' or 'stereo' FM receiver? Click here... patrickcambre Electronic Projects Design/Ideas/Reviews 16 28th July 2005 05:44 PM
Please help me repair a stereo receiver 68rustang Electronic Projects Design/Ideas/Reviews 6 27th December 2004 07:45 PM
