+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 18
Thread: Need a McGyver solution to charging a 12v battery
  1. #1
    petekw Newbie
    Join Date
    Sep 2009
    Posts
    6
    Default Need a McGyver solution to charging a 12v battery
    Hey all! Great forum going here, glad I found it!
    I need to charge a 12V battery with improvised means. The battery is lead-acid, sealed in gel, of the valve-regulated type. The official charger is (I think, from this ebay post) a 17V 1700 mA type. I need to charge it every now and then, and even a half-charge would be more than enough.
    So my approach: I have an old transformer lying around from my electronics classes in college. I have tried to trickle charge it at 12V 300 mA but even after 12 hours I saw no improvement.
    My transformer is rated at 5V 1000mA and 12V 300mA.
    But I have found two leads that have a voltage difference of 18V. I dont know how much amperage will come off there...
    My questions are:
    1-- Is it safe for me to attempt to charge it at 18V? (5 minutes? 30 minutes? an hour?)
    2-- How much amperage would I expect to be able to draw when using the leads that measure at 18V?
    3-- Should I totally change my approach and just charge it off my car's battery, as if I was jumping another car?
    I bought this electric mower for 20$, but it came with no charger. The previous owner had run leads to attach directly to the battery (the bolts coming through the top). See below:
    Our yard is quite small so I dont need a super professional approach, just one that works enough. Thanks!!!! all help is appreciated!
  2. #2
    mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,793
    Your (+/-)12V should have 24V between them, capable of 300mA. To charge your battery, place this 24V in series with a 12V tail light bulb from the car (5 watt, not 27 watt).
    Monitor the voltage and don't let it exceed 13.8V. 30-40 hours if it's a totally flat 12AH battery, at 300mA.
    The lamp is NOT a charge monitor, it's just a resistor! It'll light, not at full brightness, and will stay about the same even after your battery is done.
    de KI6RWX
  3. #3
    petekw Newbie
    Join Date
    Sep 2009
    Posts
    6
    Quote Originally Posted by mneary View Post
    I like the idea. Certainly in theme with my thread title
    Follow up:
    What is the typical resistance of the bulb you mentioned? I have some spare bits and pieces around - it's probably easier for me to pull some resistors off the shelf than remove a tail light bulb.
    Also, Why should I use the 24V option? There is indeed a set of leads that reads 24V, but I decided not to mention it because the 18V option was already exceeding the 17V original charger.
  4. #4
    unclejed613 Excellent unclejed613 Excellent unclejed613 Excellent unclejed613 Excellent unclejed613 Excellent
    Join Date
    Apr 2009
    Posts
    549
    Blog Entries
    9
    the bulb works as a ballast, because it's resistance is nonlinear. it's resistance rises with temperature. with 24V across the bulb and battery, the bulb will "soak up" the difference between the 24V and the battery voltage. in doing so, it will also act as a current limiter. as the filament temperature rises, the resistance rises, until it reaches an equilibrium point and levels off. then as the battery charges, the current drops, the temperature drops and so the resistance drops, and the bulb maintains equilibrium. with the 24V source, you will want to monitor the battery voltage often. i have found it more accurate to actually disconnect the battery from the charger, and then measure the battery voltage. batteries with weak cells will measure much higher with the charger connected, because of increased internal resistance in the battery. i have a 10A open frame power supply i use occasionally for charging gel cell batteries. the supply has foldback limiting, which means if a preset current is exceeded, the regulator will start dropping the output voltage until the current is at the preset level. i find that by setting it to about 5 amps or so, the power supply will source the charging current and at the same time the regulator output will be folded back to the present battery voltage. as the battery voltage rises, it can be monitored with a meter. there is one problem, however. if the battery has a weak cell, the charging current won't trigger the limiter, and so the battery's state of charge can't be accurately monitored with the supply attached. a small 300mA charger with a lamp is going to behave similarly to my foldback limited supply, but if there is a weak cell it will read higher than the actual battery voltage with the charger connected.
    E=mc˛ (+/-1dB)
    "If a curl of smoke is seen, the technician will soon experience the cause of difficulty"........ CTX arcade game rgb monitor service manual 1985
    DC-to-Daylight Blog (on this forum):
    http://www.electro-tech-online.com/blogs/unclejed613/
  5. #5
    HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent HiTech Excellent
    Join Date
    Jun 2006
    Location
    Penna. USA
    Posts
    2,506
    Just go get a small automotive battery charger... they are cheap and you can use it on your vehicle battery too. The variety that provide a switchable 2, 5, 10 amps are very common and affordable.
  6. #6
    petekw Newbie
    Join Date
    Sep 2009
    Posts
    6
    Quote Originally Posted by unclejed613 View Post
    Thanks for taking the time to educate me about the bulb's role. Good stuff.
  7. #7
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,793
    I need to reiterate: If you're using a McGyver circuit that doesn't have charge monitoring, you need to monitor the voltage manually. And often.
    The bulb could be replaced by a resistor of 30-35 ohms 20-25 watts. Although P=V*I says <10 watts, it would burn any thing or person that gets too close (150 deg C is common). I suggested the bulb because most people don't keep a good assortment of 25 watt resistors, and a hot lamp is a nice visible reminder not to touch.
    I suggested 24V because I didn't really trust the "18V" that you happened to find. In retrospect, I could have guessed that you found 17V between the +5 and -12 lines. If you use the 17V, your resistor would be 10 to 12 ohms, 10 watts. Again, arithmetic might say <5 watts but a 5W resistor will be a burn hazard.
    de KI6RWX
  8. #8
    petekw Newbie
    Join Date
    Sep 2009
    Posts
    6
    Thanks!! I dont know how I measured 18V... You were right it -- I double checked it and I got 17.2V, which is exactly what I need (except this charger does not have too much current output...).
    I got these bulbs for 2$: two filaments, one @ 27Watts and the other at 8.3Watts. The inner lead's filament is like a straight thick wire, and measures about 2.2Ω I suspect this is the 27 watt filament because it is much thinker than the outer lead's filament - which is a thin coil and measures about .7Ω.
    Please correct me if this assumption is wrong -- If I assume the output is limited to ~300mA, then :
    P=V*I = 17.2 * .3 = 5.16W.
    SO I could use either filament but just to be safe I will start by using the one which I guess is the 27 Watt filament.
    Thanks again!
    Also the cheapest battery car charger I could find in a store was like 40$. I like this cheap option better.
  9. #9
    petekw Newbie
    Join Date
    Sep 2009
    Posts
    6
    Seems to be working:
    I have it hooked up to the 17V pins. There is a dull glow from the bulb.
    Time (min) ..........Volts measured on battery
    0 ................. 12.51
    1 ................. 12.71
    2 ................. 12.79
    3 ................. 12.81
    5 ................. 12.82
    10 ................. 12.84
    20 ................. 12.85
    40 ................. 12.86
    current was measured at 340 mA.
    I dont really know how long to push it...
  10. #10
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,793
    Well, you're kind of confused, but all is working. Your power supply is probably not current limited, so you're using the bulb for limiting. You are only applying about 4V across the bulb, so you its power is only 4*0.3 or 1.2W. If you used the 8W filament, it would be not be bad for the filament, would reduce the strain on the power supply, but take longer to charge.
    How long to push it? Remember we said a flooded lead acid battery is full, and you must stop, once it reaches 13.8V. But if you have enough to mow the lawn feel free to stop any time before then.
    de KI6RWX
  11. #11
    petekw Newbie
    Join Date
    Sep 2009
    Posts
    6
    Ok hmm I have measured it at at 340mA and after an hour of charging it was around 12.9 Volts and it seemed to have plenty of power when I started mowing. But then it was drained dead in like 3 minutes. So I only got 1/4 yard mowed. This time I'll charge it for like 4 hours.
    Thanks for all the advice.
  12. #12
    giftiger_wunsch Newbie
    Join Date
    Jun 2009
    Location
    Kent, England
    Posts
    813
    If you've only added about 340mAh of charge to an otherwise flat battery, it's no wonder it didn't last long trying to power a lawnmower. Charge for at least a few hours and try again.
    Good riddance, ETO .
  13. #13
    Join Date
    Apr 2009
    Posts
    549
    Blog Entries
    9
    if the battery has removeable vent caps, remove them while charging the battery, and put them back on after charging the battery. my brother once overcharged a car battery without removing the vent caps. the battery blew up literally in his face from the pressure. fortunately, it was cold very out and he was wearing heavy clothing and a ski mask, and he wasn't injured or burned. also, during and after the battery is charged, don't smoke near it, as the hydrogen that bubbles out of the battery is very flammable (and explosive if it happens to be in a 2:1 ratio mixture with oxygen).
    E=mc˛ (+/-1dB)
  14. #14
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,793
    Didn't we say in an earlier message say that this tiny charger would take a couple of days? I didn't notice that you only charged for 40 minutes; my bad on that one.
    If it's flat right now, then loosen the vents like unclejed614 advised, and charge it for at least 24 hours (that's less than 8 Ampere Hours). If it's a 20AH battery, it'll take three days to fully charge. I don't recall reading how big your battery is; just keep an eye on the voltage.. Stop charging if it ever reaches 13.8.
    With only 340 mA charging current it's a slow proesss, but you wanted it cheap...
    de KI6RWX
  15. #15
    Oznog Excellent Oznog Excellent Oznog Excellent Oznog Excellent Oznog Excellent
    Join Date
    Apr 2004
    Location
    Austin, Tx
    Posts
    2,765
    That's probably a half-U1 battery inside there.
    Those things are expensive for good ones, and you've gotta be very careful about how you charge them.
    Your plan of charging it "just enough to do the yard" will destroy them. Lead acid needs to be stored fully charged every time. But, leaving a "dumb" charger on too long will damage them in a different way. Even putting a trickle charger on them will sort of lead to the same problem, it'll take much longer to charge, but after a few days of charging you could easily forget and find weeks later that it's still on the charger.
    You need a real charger. Those batts, if they're still good, can easily be toast from bad maintenance including poor chargers.
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. Battery charging
    By InvalidApple in forum Electronic Projects Design/Ideas/Reviews
    Latest: 17th September 2009, 04:36 AM
  2. I'm Charging my Battery
    By watzmann in forum General Electronics Chat
    Latest: 14th September 2007, 12:34 PM
  3. regulate a 12v battery at 12v, 5A
    By alexc in forum General Electronics Chat
    Latest: 9th August 2006, 08:46 AM
  4. Replies: 13
    Latest: 1st August 2006, 08:38 AM
  5. Charging a 12v battery with Solar panel..
    By barrymons in forum Electronic Projects Design/Ideas/Reviews
    Latest: 21st April 2006, 12:44 AM
Tags for this Thread
