Go Back   Electronic Circuits Projects Diagrams Free > Electronics Forums > Repairing Consumer Electronics
Repairing Consumer Electronics If you're trying to fix an electronics device like a TV, Stereo, etc you can discuss it here.
Old 29th June 2009, 06:15 AM   #1
Exclamation I need help
I have a Telefunken model TTV-210 TV. Picture is perfect but no sound - only noise and sometimes radio station. I have replaced everything related to sound - even swapped components with a working TV (same model). It seems to be a setup problem - cannot find sound settings in the menu.
Outop is offline
Old 29th June 2009, 06:17 AM   #2
Cable/Antenna setting?
de KI6RWX
mneary is offline
Old 29th June 2009, 07:06 AM   #3
Not sure what you mean. It uses external antenna. It has a setting for TV/AV. When DVD player or TV game is connected - sound is O.K.
Outop is offline
Old 4th July 2009, 04:13 PM   #4
Sounds like an internal problem. If the receiver works with external audio sources only, then the fault could be an electronic switch. Probe the interior ( carefully!) with a signal tracer around the speaker wires, including the external source inputs. Without identifying how the audio is switched, I can be of no further help.
shokjok is offline
