Go Back   Electronic Circuits Projects Diagrams Free > Electronics Forums > Repairing Consumer Electronics
Repairing Consumer Electronics If you're trying to fix an electronics device like a TV, Stereo, etc you can discuss it here.
Old 17th June 2009, 12:04 PM   #1
Default SONY lcd mornitor, power seens ok. video signal switch off for no reason
picture will just disappear after running sometime.
If switch off/on, sometime the picture can back.
Or off a half hour, it will back again....
seens video control/switch wrong?
any body know this problem from sony lcd mornitor?
togtoo is offline
Old 17th June 2009, 02:18 PM   #2
Default Sony LCD Monitor
If it's one of the older LCD monitors with an external power supply you might want to open up the power supply and replace the larger value capacitors. I had this same problem and this cured it.Good luck
DrDave is offline
Old 18th June 2009, 09:53 PM   #3
ok...I tried to parallel a knowing good cap and
saw improvement! So, it is right way to go.
I am here also wonderring about: what if I simply
parallel several ceramic 4.7uF to solve ERS problem?
Keeping what it has..
togtoo is offline
Old 18th June 2009, 10:12 PM   #4
Remove the faulty electrolytic, and replace with a 105 degree low-ESR electrolytic of the same value, and equal (or higher) voltage.
You're not going to be able to fit enough ceramic capacitors in the space available, and they probably don't have a very low ESR anyway.
Nigel Goodwin is online now
Old 18th June 2009, 10:44 PM   #5
Smile
u will see the faulty electrolytic- it may have a split case or be leaking and there may be more than one to replace-as nigel said replacements need to be 105 degree hi temp types and be the correct voltage rating as well...........
all "txt speak" has been removed from this post for the benefit of all other forum members who may get confused!!!
sheldonstv is offline
lcd, mornitor, power, reason, seens, signal, sony, switch, video
bypass sony amp switch stevo1173 Repairing Consumer Electronics 0 25th April 2009 10:56 AM
Video signal processing jaimegmr Electronic Projects Design/Ideas/Reviews 2 24th October 2008 10:22 PM
RGB video signal +Sync signal m_ghaff General Electronics Chat 1 14th May 2006 07:18 AM
Video Signal narco General Electronics Chat 2 23rd November 2004 03:08 PM
Sony CCD-V801 Video Camera Dex Datasheet/Parts Requests 0 31st December 2002 06:22 PM
