Go Back   Electronic Circuits Projects Diagrams Free > Electronics Forums > Repairing Consumer Electronics
Repairing Consumer Electronics If you're trying to fix an electronics device like a TV, Stereo, etc you can discuss it here.
Old 18th June 2009, 12:47 PM   #16
or if you have a 2 channel scope (most are these days) put it in ADD mode with ch2 inverted (this makes it subtract). hook ch2's input to the "hot" ground (do NOT connect the scope ground to the "hot" ground, connect the scope ground to the chassis) and adjust the V/div for full scale deflection. then connect ch1 to the "hot" ground (with ch2 still connected), and adjust ch1's V/div until you get a straight line. once that is done, you can use ch1's probe to see the drive signals, etc on the "hot" side of the supply, and have plenty of isolation to the scope.
most people don't know their scope has this capability, and get an isolation transformer instead. or they more commonly take the dangerous shortcut of cutting the ground pin off the scope's power cord.
E=mc˛ (+/-1dB)
"If a curl of smoke is seen, the technician will soon experience the cause of difficulty"........ CTX arcade game rgb monitor service manual 1985
DC-to-Daylight Blog (on this forum):
http://www.electro-tech-online.com/blogs/unclejed613/
unclejed613 is online now
Old 18th June 2009, 02:50 PM   #17
This comes up time and time again - I would suggest using a twin beam scope in that way is probably the most dangerous of all three methods?.
But in all three cases you shouldn't be doing this unless you know EXACTLY why you're doing it that way, and the reasons why it's safe under some conditions, and not under others.
Personally I wouldn't consider using an earthed scope, it's far too dangerous an instrument if you know what you're doing.
For anyone who doesn't know what they are doing, use an isolation transformer - it's the safest method for beginners.
Old 18th June 2009, 03:14 PM   #18
Originally Posted by Nigel Goodwin View Post
No, there should be no high voltages anywhere near where you should be scoping, on the secondary side of the PSU.
Sorry maybe I should have made it clear, the inverter is on the same PCB and right next to the secondary side of the SMPSU.
Thanks for the info the ground was a lapse of concentration on my behalf, I will look into getting an isolation transformer .
DMW is offline
Old 18th June 2009, 05:52 PM   #19
I think we have different ideas of what 'near' means
monitor, tft
When my laptop is charging and I hook my monitor up to it, the monitor starts getting Qaiphyx General Electronics Chat 11 3rd August 2008 11:56 AM
new LCD monitor Thunderchild General Electronics Chat 0 4th April 2007 10:07 PM
tv/monitor dryden_burton General Electronics Chat 13 12th May 2005 11:01 PM
monitor/tv dryden_burton Electronic Projects Design/Ideas/Reviews 3 11th May 2005 03:31 PM
The use of a Monitor! matasoft General Electronics Chat 8 3rd December 2003 03:25 PM
