Go Back   Electronic Circuits Projects Diagrams Free > Electronics Forums > Repairing Consumer Electronics
Repairing Consumer Electronics If you're trying to fix an electronics device like a TV, Stereo, etc you can discuss it here.
Old 26th November 2008, 10:34 PM   #1
Default LED Cooker control module
The LED panel on my cooker has failed, the module appears to control the functions OK, but the clock display is not illuminating, I have done some searching on the web, but am not happy to part with £40 for a exchange module, on examination it is only the LED module that has failed, it is one of the large glass encased types, but cannot source the parts, if anyone can help it would be really appreciated. Its a belling cooker, and I think the timer module is part no. 316 T85 (a four wire module, mains in, and a switched pair) manufacturers are hopeless, quoting in excess of £120!!!! any help or suggestions, greatly appreciated, Karl.
JKF1000 is offline
Old 27th November 2008, 07:51 AM   #2
Are you sure it's LED?, as you say 'glass enclosed', that sounds more like a flourescent display module. If so, the most common problem is failure of the heater supply to it (it's essentially a valve), often dry joints, or a capacitor which couples the AC to it.
Nigel Goodwin is online now
Old 27th November 2008, 08:17 AM   #3
Hi there Nigel, and thanks for the responce, I will pull the module again later and check it out, I am assuming it's a simple fault because, apart from the controller chip, there are barely a handfull of additional components, one of which is a mains coupled cap, will update after further investigation, Karl.
JKF1000 is offline
Old 27th November 2008, 08:19 AM   #4
While you are there post a picture (front and back) of the display and the model number for the cooker. You may get lucky.
BCHS/3v0's Tutorials
3v0 is offline
Old 27th November 2008, 12:03 PM   #5
I have had another look, the board is manufactured by Invensys, model no.D78559, have looked at your sugggestion and checked all for dry joints etc, has all now been re-soldered, but still no signs of life. Have included pics of the module if it helps. One thing I have noticed in pic2, at the top left of the display is a piece of metal inside the display that appears to be bent, it looks worse when you have module in your hand, I have turned up the contrast a bit to try to get more detail. As I said before, the timer circuit still appears to work and control the oven, its just the display side, Karl.
LED Cooker control module-dsc_1146.jpg   LED Cooker control module-dsc_1147.jpg   LED Cooker control module-dsc_1152.jpg   LED Cooker control module-dsc_1153.jpg
JKF1000 is offline
Old 27th November 2008, 01:07 PM   #6
Yes, that's a vacuum flourescent display it should have a low AC voltage feeding the heaters (the outside pairs of pins at each end).
Old 27th November 2008, 01:25 PM   #7
do you know what voltage levels I should be looking for?
JKF1000 is offline
Old 27th November 2008, 02:00 PM   #8
It's usually something like 3V AC, but often DC shifted from ground, commonly negative.
There looks to be VERY few components on that board!.
Old 27th November 2008, 02:47 PM   #9
thats what makes it more interesting, there's virtualy nothing on the board to go wrong!!
JKF1000 is offline
Old 27th November 2008, 03:26 PM   #10
A VFD display when working should show very faint orange filament wires.
Bill
Smart Kits build Smart People
Old 27th November 2008, 03:49 PM   #11
Photo's 1 & 2 clearly show that the heater elements are broken.
You need a new display.
SYE is offline
Old 27th November 2008, 05:28 PM   #12
yes, I see it, have spent last hour and a half online trying to source one, no luck, anyone any ideas?
JKF1000 is offline
Old 27th November 2008, 09:35 PM   #13
They are often made to order.
Bill
Old 27th November 2008, 10:35 PM   #14
Could be the best bet is to pay the £40 for the exchange module and be happy that you could get it at all.
3v0 is offline
Old 27th November 2008, 10:51 PM   #15
Looks like you may be right, ah well was worth a try, and thanks again to everyone for the help and advice, greatly apppreciated. Karl.
JKF1000 is offline
control, cooker, led, module
Need help for induction cooker/ heater muki55 Electronic Projects Design/Ideas/Reviews 9 27th March 2009 02:46 PM
Control of EW 162 LCD display module fejesg Micro Controllers 2 7th November 2008 08:03 PM
Double Boiler/Pressure Cooker Combo crashsite Math and Physics 6 11th October 2008 06:32 PM
PIC with RF module as remote control bananasiong Micro Controllers 22 20th March 2007 01:59 AM
which igbt module to use for speed control garg29 Electronic Projects Design/Ideas/Reviews 10 22nd December 2004 04:52 PM
