| Renewable Energy Discussion of Solar, Wind, Hydro and main stream renewable energy topics including RE projects. |
Does anyone have a circuit diagram for a charging circuit---> 12V car alternator charging a 12V lead acid battery....... I want to cut down the electricity bill ![]() The charging circuit will be connected to an inverter that gives an output of 240V AC.
__________________ Learn without thinking begets ignorance. Think without learning is dangerous. | |
Usually the alternator comes with a built in regulator. If it doesn't have one, you could pick one up at an auto wrecker for cheap. What are you going to turn the alternator with? They require quite a high RPM to give any decent output.
__________________ Inside every little problem, is a big problem trying to get out. | |
| | #3 | |
__________________ Learn without thinking begets ignorance. Think without learning is dangerous. | ||
And unless your able to run the electric motor for free then you won't save on any electricity.
| | #5 | |
| | #6 |
Every stage will lose energy via heat. You'll only get a percentage of the original power you put into it.
| | #7 |
Gosh I wish schools would start teaching basic practical math and science again. I really miss the common sense it instills in people.
__________________ "Issue a general safety warning. Then look the other way and allow stupidity the chance to eliminate itself." -- tcmtech "Those who can, Will. Those who can't, will achieve positions of power over those who can and then promptly stop them." -- tcmtech "Your impossibility may just be my day to day routine." -- tcmtech | |
| | #8 |
| | #9 |
dude....u have to get ur basics right....u cannot continue otherwise
| | #10 |
yikes im never going to ask a question on behalf of someone else again. ![]() ![]() ![]() ![]() ![]() ![]() ![]() :eek :![]() ![]()
__________________ Learn without thinking begets ignorance. Think without learning is dangerous. Last edited by fantabulous68; 13th November 2009 at 09:32 PM. | |
| | #11 |
Here's what you could do, but won't really save you any on electricity. Use alternator in Van to charge up a battery while driving, then use an inverter off the battery to get your 220v. Or if you didn't have an inverter you could get a 12v motor, hook it up and spin a 220v generator alternator. Still your paying for the electricity in the gas your using.
| | #12 |
hey, its okay fantabulous. even the most experienced guys out there do make mistakes....and making mistakes is the best way to learn...and where is a better place than the forum to make mistakes? where you have experienced people helping you out...so you can always learn from them...dont worry at all...and if its your friend who posed the question, tell him to join the forum too and ask his doubts himself, so he learns too.... cheers, deepak | |
| 12v, acid, alternator, battery, car, charging, lead |
| Simple Charger for 12V Lead-Acid Batteries | bountyhunter | Electronic Projects Design/Ideas/Reviews | 8 | 4th September 2009 12:25 AM |
| upgrading from 12V 12Ah to 14Ah Lead Acid | billericayboy | General Electronics Chat | 2 | 23rd March 2009 06:35 PM |
| lead acid battery charging | dimper129 | General Electronics Chat | 3 | 14th April 2008 08:06 PM |
| DS2438 with 12V lead acid battery | monkeytennis | General Electronics Chat | 2 | 29th August 2006 01:45 PM |
| 12v Sealed lead acid battery charger | andi_n2004 | Electronic Projects Design/Ideas/Reviews | 1 | 27th April 2004 01:52 PM |
