| Renewable Energy Discussion of Solar, Wind, Hydro and main stream renewable energy topics including RE projects. |
| | #31 |
Well go buy one then. YouToobe is full of crap, they have "working" HHO motors too!
| | #32 | |
You can plug certain old motors into a motor controller to reduce the input voltage when it detects that the motor is lightly loaded. It only works with motors which are oversized for their task. Each old motor needs an individual controller because the load must be detected separately. [edit] A short demo like the one on YouTube can easily be arranged using a Variac. [edit] Once started, an oversized motor will run well on reduced voltage provided its conditions are carefully monitored. A sophisticated motor controller can and does save power by monitoring the work being done and applying the correct voltage. But the motor alone has the final say about the relationship of I with respect to V at its terminals. They sold devices for a while called "Green Plug" and I was suckered into buying one. Problem was, my fridge wasn't old enough. The Green Plug cheerfully reduced the voltage and my poor fridge hummed and buzzed and clicked and quit. Saved a lot of energy.
__________________ de KI6RWX Last edited by mneary; 20th September 2009 at 01:13 AM. Reason: confused ext/int in first para - sorry | ||
| | #33 |
mneary, you've posted helpful & constructive information that appears credible as opposed to blind accusational nonsense. Thank you for that. I've given you some reputation points. | |
| | #34 |
ignisuti said: Quote: Originally Posted by audioguru View Post Your home meter does not read apparent current. Technically correct, but I must state again that a poor power factor makes you use more Real Power to run the same load of laundry. The Real Power is read by your home meter. Therefore, you end up paying more on your electric bill because of the poor power factor. OK, so then, install larger diameter wire in your home so you have lower I^2 losses. boB | |
| alternative, correction |
| Passive power correction | technogeek | Electronic Projects Design/Ideas/Reviews | 2 | 16th August 2007 06:41 AM |
| Mileage correction... | Rescue1 | General Electronics Chat | 10 | 12th July 2005 12:38 AM |
| Error Correction Coding | Celestie84 | Electronic Projects Design/Ideas/Reviews | 1 | 21st May 2005 01:57 AM |
| correction(s) to the 4-stepper circuit please | ajay_kumar_d | Electronic Projects Design/Ideas/Reviews | 1 | 18th March 2004 09:22 PM |
| correction(s) to the 4-stepper circuit please | ajay_kumar_d | Electronic Projects Design/Ideas/Reviews | 0 | 18th March 2004 06:49 PM |
