Go Back   Electronic Circuits Projects Diagrams Free > Electronics Categories > Renewable Energy
Renewable Energy Discussion of Solar, Wind, Hydro and main stream renewable energy topics including RE projects.
Old 30th March 2009, 03:08 PM   #1
Default Need Datalogging volt and ammeter for solar project
Hello
I need an up to 1000 mA and 12 v meter with datalogging capabilities into a .csv file for a solar project.
please post any recemendations
wtperry00 is offline
Old 31st March 2009, 02:05 PM   #2
I use a Protek 506 for that.
duffy is offline
Old 31st March 2009, 04:31 PM   #3
It seems that that is obsolete. It says on Protek's Website. Also it is way to expenisve for my budget. I'm sorry I forgot to mention it, but I was looking for something under $100 if possible.
Old 31st March 2009, 05:21 PM   #4
How many samples at what resolution are you hoping to log?
Bill
Smart Kits build Smart People
Old 31st March 2009, 06:20 PM   #5
3 samples, I am willing to buy 3 meters if this is not possible. What exactly does resolution mean?
Old 31st March 2009, 07:36 PM   #6
He means samples per second, what you are talking about is channels. Resolution is how many digits of accuracy you expect.
duffy is offline
Old 31st March 2009, 07:48 PM   #7
The 506 is not a logger but you can connect it to your PC.
Bill
Old 31st March 2009, 07:53 PM   #8
Maybe something like this:
Data Logger Starter Kit
They have a USB one (DI-148U) for $50.
Ken
KMoffett is offline
Old 31st March 2009, 08:01 PM   #9
blueroomelectronics, it dosent need to be very accurate maybe +- 100 mA +- 1 v also it does not need to be a datalogger as I can connect it to a PC. Also 1 sample per two minutes should be a good sample rate.
KMoffett, Do I need extra parts? Or do I only need the logger?
Old 2nd April 2009, 04:40 PM   #10
I use one of these. Its more than $100, but as a data logger it does want you want. I made a test fixture that records voltage at one channel and current on the other. I have run it as long as 20 days at a time. you can select a sampling rate where the .csv file is manageable.
MikeMl is offline
Old 2nd April 2009, 04:53 PM   #11
Since the input is +/- 10vdc you will need two resistors to make a voltage divider to scale the ~+12v down to +10V. You will also need a low resistance resistor (0.5Ω/2W) to convert current to voltage that the converter can read.
Ken
KMoffett is offline
ammeter, datalogging, project, solar, volt
Digital ammeter project scottraynor Electronic Projects Design/Ideas/Reviews 12 26th June 2009 02:18 PM
Analog Volt/Ammeter solis365 General Electronics Chat 20 30th March 2009 07:41 PM
PIC24 as voltmeter/ammeter for solar system - fluctuating readings albad Micro Controllers 16 24th February 2009 06:51 PM
What kind of data storage medium can be used for datalogging? potoole64 Electronic Projects Design/Ideas/Reviews 2 12th December 2008 08:56 PM
Uni-T UT70B Datalogging problem fsahmed General Electronics Chat 8 18th October 2006 11:10 AM
