I bought a couple of panels on ebay that are 20 watts and listed as 12 volts but they are actually 17.5, now I'm aware that i will need more than 12 volts to charge lead-acid batteries but surely 17.5 is a lot. do charging controllers work with switch mode cicuitry ? so that the voltage can be dropped and the amperage increaased a little ? or am I best just using a proper smps to do it ?
__________________ I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) www.simonsphotography.org.uk/ - My other hobby www.rushdenrotaract.org.uk/ - make a difference and have fun ! Never buy "Trust" products, all mine broke !!! | |
| | #2 | |
Was that the off load voltage.? Solar panels have a highish output resistance, about 5R or so. So at 1amp you may only get ~12.5v You may require a reverse blocking diode if the panel is connected to a battery.
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 15th March 2009 at 04:00 PM. | ||
well its 21+ volts no load and on the back says 17.5 volts, if I count up the cells and calculate them all in series @ 0.5 V each (36 cells X 0.5 V) its 18 volts so thats about right
| | #4 | |
Have you an ebay link to panels.?
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ | ||
| Brand New 20 Watt Solar Panel on eBay, also, Solar Panels, Gadgets, Consumer Electronics (end time 14-Mar-09 15:23:40 GMT) on the back of the panel it says 17.5 volts and 1.15 amp well I got up to 1.25 amps shor circuit and 21.5 volts open circuit
| | #6 |
A charge controller is a good investment, unless you get free batteries. A 5 amp controller cost around $20, an new 10 AH battery is around $40...
| | #7 | |
As Harvey says a charge controller is required. from your link Code: Electrical Specs: Max Power: 20WP Open Circuit Voltage (V): 21.88 + 2 Short Circuit Current (A): 2.49 + 0.4 Max. Power voltage (V): 17.64 + 2 Max. Power Current (A): 1.135
| | #8 |
Take a look at how the RV industry handles charging lead acid battery's. For instance, the Progressive Dynamics Converter/Charger. Using a 14V-14.1 is a little low for flooded lead acid type, and is usually the setpoint for gel and maybe some AGM type of batteries. Also its good if a charge controller has an equalizer cycle, if the battery's are flooded lead acid type, either manual or automatic. Going with a lower end solar charge controller, like the Morningstar Sunsaver/Sunkeeper, are usually just an analog pwm device. The upper end controllers out there use MPPT, and are of the programmable type. Last edited by nickelflippr; 15th March 2009 at 05:17 PM. Reason: qualify equalizing charge to lead acid type | |
| | #9 |
ok so do these controllers just dissipate the 17.5-12.5ish volts or convert it reducing voltage and oncreasing amps ?
| | #10 |
| The impression I get is that you would lose some efficiency with a straight PWM controller (depending on temperature, overcast conditions, etc.). What kind of voodo electronics goes on, that makes MPPT better, haven't a clue. The MPPT thing probably just not worth the effort or expense for a small solar array?
| | #11 |
what is MPPT ? I'm guessing that I do not need straight 17.5 volts to charge a 12 volt battery and so there being a good 25 % over voltage a decent switch mode controller will conver the 4-5 volts extra into extra current making it a bit more efficient. ok so I can't connect the battery straight to a smps as it still needs to be "charge controlled" what sort of charge controlling goes on ?
| | #12 | |
If there isnt an internal blocking diode, then an external shottky will lose another 0.45V. You could use a shunt reg but these are wasteful. There maybe some decent controller designs on the web. I would be interested on seeing your results when you have it running.
| | #13 |
well the panels came with a 10 amp standard diode (I suppose just for the sake of it) I'd prefer to used a skottky one. If I'm to build my own I need to know the "logic" of charging batteries, I'm sure it can be done with comparators and possibly some digital logic (ok ok a pic can do the lot but my pic skills go as far as knowing the wonders they could do for me if I knew how to program them). As for the diode well, if i was designing my own I'd be using the panel to power the SMPS first so that surely would act as a block anyway from the battery discharging into the panel. So I'd step down the voltage hopefully increasing the current by about 20 % and charge the battery via the appropriate "logic" which as far as i know is when "x" voltage is reached its charged but I'm sure i need to know more than that....
| | #14 | |
Do you need any help with a charger design, I have used 12V SLA 7AH and 20AH battery chargers on a number of projects.?
| | #15 | |||
TC said: Quote:
ecgibbs said: Quote:
| charging, regulators, solar |
| Charging EEE pc from a solar panel? | things | General Electronics Chat | 3 | 5th December 2008 05:47 PM |
| Solar charging | jaycool1995 | Electronic Projects Design/Ideas/Reviews | 7 | 19th August 2008 05:13 AM |
| charging NiCd from solar cells | mettam | General Electronics Chat | 21 | 1st October 2006 04:14 AM |
| Charging a 12v battery with Solar panel.. | barrymons | Electronic Projects Design/Ideas/Reviews | 11 | 21st April 2006 01:44 AM |
| Charging System of Solar Car | devonsc | General Electronics Chat | 3 | 21st December 2004 05:43 AM |
