| | #46 |
| erm I won't stop at 40 W of solar panel, I intend to gradually increase the panels but don't want to be buying batteries all the time, larger batteries will be more durable I assume ? last longer cost less per W (assuming I want all that power). If I get 12 volts worth I won't really be able to add to it later will I ? I was led to beleive that 24 V inverters are more robust than 12 V ones and I'm pretty sure overal efficiency of a 24 V set up is going to be better than 12 volts.
__________________ I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) www.simonsphotography.org.uk/ - My other hobby www.rushdenrotaract.org.uk/ - make a difference and have fun ! Never buy "Trust" products, all mine broke !!! | |
| | #47 | |
.Inverter? Jeez, if someone would just answer 'one' of those urgent,... need 1000W inverter, pls include schematic, pcb files, and source code, postings!....haha Any candidates for a combo inverter/charger?
| | #48 |
General idea with 2 different car batteries is as attached.
| | #49 |
Thunder if you charge them separately you have to discharge them separately. So you'd basically have two separate 12 volt systems.
| | #50 |
well then I'll return the battery and get some bigger ones later, only thing is if i get 12 volts of batteries will I be able to put another 12 volts worth in series later ? me thinks not, that why I was going to try for the 24 V straight off
__________________ I AM the exeption that disproves the rule in many ways but the rules still apply (unfortunately) www.simonsphotography.org.uk/ - My other hobby www.rushdenrotaract.org.uk/ - make a difference and have fun ! Never buy "Trust" products, all mine broke !!! Last edited by Thunderchild; 22nd March 2009 at 01:13 AM. | |
| | #51 |
I find the best cost effective batteries are the ones removed from telephone exchanges - they can be 2.5v, 6v and 12 volt that I have seen and are gel batteries designed to stand for long periods as well. I used some 120ah ones which were over 6 years old and they were still fully functional - they do come up on ebay pretty often. If your budget extends to it a good charge controller is recommended and would handle future expansion as your array increases. | |
| | #52 |
well I'll use a 5 A SMPS for now as a charger just to make the most of the power I'll be getting, I'll worry about a full blown controller later.
| | #53 |
Hi Been in the shed as the topic of Gel batteries came up, I have a 12v 35AH gel battery that I would like to safely solar charge.I want to run from this an host of LED. garden lights. The idea is to use recycled Jam jars to make the garden lights and if I say that there might be approx 10 lights each having say 4 LED's in them. Should I purchase an off the shelf solar trickle charger or construct something? Regards Mark | |
| | #54 |
for leds a ver small panel will do so if you have a decent sized battery it would withstand the constand current ? some one else is probably more qualified than me to answer that one though
| | #55 |
for leds a very small panel will do so if you have a decent sized battery it would withstand the constand current ? some one else is probably more qualified than me to answer that one though
| | #56 | |
Regards Mark | ||
| | #57 |
| It depends entirely on what you're using, you first need to monitor how much power the panel can supply (by measuring over a range of conditions) - for most panels you probably need no regulator at all.
| | #58 | |
Not much Sunshine in Wombwell. ![]() You can trickle charge the SLA at about 13.8V. The size of the solar panel will depend upon the power required by the LED's eg: current and the time the LED's are lit. [I would have a simple dark detector and an OFF timer to conserve battery power] The charge efficiency of a SLA can be 70%, so say for every unit of current you discharged from the battery you would need to recharge at 1.3 times. If you used a SMPS/controller the efficiency of the controller, say 85% would also have to be allowed for as loss. Get the local sunshine hours and intensity for your area and work out how much power you would get from say a 1mtr square solar panel. [the solar panel manufacturers data will give the power outputs]
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 29th March 2009 at 01:40 PM. | ||
| | #59 | |
![]() Solar panels or chargers seem to be sold in quite varying price ranges.I had a look in Maplins for something that I thought might be suitable-Solar-Powered 12V 12W Battery Charger > Maplin I could maybe add a couple together.This is £40 ish for the one. At Farnell not much available other than a £385 panel. Think I need to educate myself first on solar cells and paneling. Not been vey lucky also at finding the sunshine hours and intensity in my area. Keep on digging. ![]() Regards Mark | ||
| | #60 |
hi Mark, The Maplins data says that if the SLA battery is over 12AHr, [yours is 35Ahr] no controller is required. Also the panel is already fitted with a reverse blocking diode. Regards EDIT: a starting point. et Office: Regional Climate: North East England
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 29th March 2009 at 05:43 PM. | |
| charging, regulators, solar |
| Charging EEE pc from a solar panel? | things | General Electronics Chat | 3 | 5th December 2008 05:47 PM |
| Solar charging | jaycool1995 | Electronic Projects Design/Ideas/Reviews | 7 | 19th August 2008 05:13 AM |
| charging NiCd from solar cells | mettam | General Electronics Chat | 21 | 1st October 2006 04:14 AM |
| Charging a 12v battery with Solar panel.. | barrymons | Electronic Projects Design/Ideas/Reviews | 11 | 21st April 2006 01:44 AM |
| Charging System of Solar Car | devonsc | General Electronics Chat | 3 | 21st December 2004 05:43 AM |
