Still more reading material Maxim AN484 on solar chargers. Buried in the appnote is a paragraph that claims:
So there might be your analog SMPS solution for a smallish < 10A solar array.Applications in which the solar-panel voltage is higher than the fully charged battery voltage demand a step-down converter. As an example of applications demanding a step-down converter, configuring the MAX797 controller as a current source and its internal 5V linear regulator can power the external comparators. The device is well suited for charging a car battery from two 12V solar panels.
Thinking out loud, it would look like a Pic 16HV616 would do the same job as the Maxim797 part. The pic has an internal 5V regulator, a-d, a couple of comparators, and a hardware PWM. Wouldn't a half bridge PWM configuration operate the external mosfet's in the same way the Maxim part does?
P.S. Forgot Max797 pdf
