| Renewable Energy Discussion of Solar, Wind, Hydro and main stream renewable energy topics including RE projects. |
Hello, I am trying to measure and compare the total daily output of two identical solar panels: one is stationary and the other tracks the sun. I know how to measure the voltage acorss a load and determine the power but what is the best way to measure the total power produced, from sunrise till sunset, on these panels? Thanks. | |
| Total energy. . .? Assuming a resistive load: .....you could make an amp-hour meter from an IC Voltage-Frequency Convertor http://www.national.com/mpf/LM/LM331.html and a shunt resistor. The Freq. increments a counter. Total count + total time = total amp-hours. .....You also need a voltmeter that displays average voltage. Use another V-F convertor and counter and divide the voltage count by the hours. .....Then you have average V and total amp-hours, and so total watt-hours. Last edited by Willbe; 28th September 2008 at 11:59 PM. | |
| | #3 | |
Are you planning to record every day or just a day or so.?
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ | ||
Do you have an 'identical' charger and storage battery for each solar panel? Just charge both batteries and then discharge each one under identical conditions (Same inverter powering the same load. Inverter should have a low-battery cutoff. Measure time to cutoff for each battery. Swap batteries and repeat the next day.)
| | #6 |
Well if you are only going to compare a couple of days differences you might consider the following lower cost but more math solution. If you wire both panels to identical load resistors and place each resistor in identical size oil baths you could trend the temperature rise of both baths over time. After you acquire the raw data you can use excel to calculate the power generated by each panel over time. I'm sure a little searching could find the proper temp/BTU/Calories/watts relationship. Again this would require more math but the hardware cost should be lower. Lefty
__________________ Measurement changes behavior Last edited by Leftyretro; 7th October 2008 at 11:10 PM. | |
| | #7 | |
Exactly how to do this with rising and falling voltages doesn't exactly jump out at me. One of these, maybe. . .? http://en.wikipedia.org/wiki/Charge_pump but I've never designed one. Or a voltage controlled current source (an FET or vacuum tube) feeding the cap, with ΔV across the cap = IΔT/C. 1v cell voltage means 1 mA into the cap, 10v means 10 mA, and for a 1000 ”F cap you apply the 1 mA current for 10 mS and you get 10 mV. Adjust the current and its duration to avoid voltages higher than the cap's rating by the end of the day. You'll need low-leakage caps. Last edited by Willbe; 8th October 2008 at 02:48 AM. | ||
| | #8 |
for watts: put some resistance on the output of each panel, and measure the voltage across the resistor. P = VČ/R power = voltageČ/resistance Last edited by leedude; 8th October 2008 at 04:32 AM. | |
| | #9 | |
As its only a few days I would suggest the following. Interface a MCP3204 , 4 channel 12bit ADC to the parallel port of a PC. Use two of the channels to monitor panel voltage and the other two channels for current. This would give W1 = V1*I1 and W2 = V2*I2 which could be plotted on the PC. If you decide on this method I could help out with the PC interface details and a simple log program.
| | #10 |
| I am aware of that. The question is how do you keep track of the power through out the day, and how do you record it and add it up?
| | #11 |
| Was my suggestion of any use.?
| | #12 |
Hello, Another approach would be to log the solar irradiance from sensors placed next to each panel. Assuming the panels are identical, this would tell you how much energy you are getting for each configuration. The comparison will vary depending on the cloud conditions and angle of the sun and panels. A clear day would be a good starting point for comparison. You can check out the following link for a "solar data logger" kit that logs solar irradiance and cummulative incident energy. Micro Circuit Labs SDL-1 The kit manual describes how to compute cumulative solar energy in kWh from logged irradiance data as well as some other background on solar power. Hope that helps. Jeff Fedison Micro Circuit Labs | |
| | #13 |
Use a sunny boy inverter. Hook it to a sunny web box and presto they track the output for you!
| | #14 |
Hi! An idea I thought ov a while ago to do something similar to this was to get a cheap electric clock & replace the one transistor ocillator with a circuit where the freq is current dependant. Not sure if the releationship between the time measured would be that linear using this method but if you made up two they could be used for comparison purposes. With suitable calibration you could make the hands ov the clock move say 1 hour if there's 1 amp flowing for that time, but as I said under or over this current it might not be linear. Hailz! Xan | |
| | #15 |
Xan, "Cheap" electric clocks (i.e. 1.5V desk and wall clocks) have crystal oscillators and are very accurate even as the batteries run down. They are not current dependent. Ken
__________________ "To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) | |
| daily, measure, output, panel, solar |
| solar panel DC current | ravaka | General Electronics Chat | 34 | 15th October 2008 05:51 AM |
| BP270 solar panel | vinke | Alternative Energy | 3 | 12th March 2008 01:27 AM |
| Solar panel LED - How does this work? | johankj | Electronic Projects Design/Ideas/Reviews | 8 | 8th October 2007 01:32 PM |
| Solar Panel | km | General Electronics Chat | 2 | 28th January 2005 01:02 PM |
| Solar Panel | km | Electronic Projects Design/Ideas/Reviews | 0 | 25th January 2005 03:52 PM |
