Repairing solar powered garden lights
Bloogoo
I'm trying to repair a set of solar powered garden lights. This wasn't working properly, and so I'm in the process of attempting to repair it. Unfortunately the circuit board was covered with some sort of polymer and I ended up destroying it trying to get everything out. Now I've got to rebuild it, and I think I have a solid plan. I'm hoping that I could get some help and just make sure that I'm going in the right direction before I invest my time and money into it. I also understand that I could just pay $20 and buy a new one, but there wouldn't be any fun in that. Additionally, I'm not certain about all the calculations, so if someone could help me out with them it would be appreciated (I don't expect someone to do the calculations, just give me some guidance as to what to calculate :D)
Details
- The garden lights have 8 LEDs (5 mm, white, I don't know any other details)
- The lights twinkle
- The solar array recharges two Ni-Cd batteries (1.2V, 900 mAh, standard charge 90 mA) during the day, and uses the battery power at night
- Solar panel gives roughly 2V in direct sunlight, not sure about amps (I believe it's the 55x55 mm panel listed on this website: **broken link removed** - 2.5v, 80 ma, 0.2 W, but I'm not 100% sure)
- There's a light-dependent resistor in the solar panel to facilitate charging
Basically that's what I had, and that's what I want to make, only better. The lights that I had were be very dim at night, and wouldn't last too long before the lights went out (1-2 hours). I would like to have lights that last longer (i.e. 3-5 hours) and be as bright, or brighter.
I've done some research online, as well as looked through some books, and I've come up with 3 different ways to make this circuit. At the moment I'm leaning towards a 555/556 timer, but there might be an easier way.
#1) 555 timer:
Because I have 8 LEDs to light, I was thinking of using a voltage doubler circuit that I found here - http://www.reuk.co.uk/Voltage-Doubler-for-Solar-Battery-Charger.htm. I'm doing this to provide more charging ability to the batteries, and hopefully get them fully charged during a day of full/semi sunlight. Also, I think, this would allow a small voltage from the batteries to light them up.
I'm also thinking of having the 555 timer be astable, and have the LEDs connected so that they will be "sinked" and "sourced" (I don't know if those are the right terms, but I got the information here - http://www.kpsec.freeuk.com/components/ic.htm#sinksource. I was thinking this would make the LEDs twinkle ... 4 sourced, 4 sinked; 4 off, 4 on, etc.
Questions
- If I were to sink/source the LEDs, would I need a resistor for them? What size should it be? Where should it be placed? I'm assuming the LEDs are 2V each, so that's 16V going to them.
- If the voltage doubler could put out 16V would there be a need for the resistors?
- How could I connect an astable timing circuit with the voltage doubler, and make it compact enough to fit into the light that I have now? Can I combine them into the same 555 timer circuit, or will I need two 555 timers?
- Can I use a 556 timer?
#2.) Reverse-engineered light
This light is shown in this schematic - http://members.shaw.ca/novotill/SolarGardenLight/circuit4.png. I noticed that there is only one AA battery (not my two), and there is an induction coil as well. Would this be a better way to go?
#3.) Solar light
These two schematics (http://www.talkingelectronics.com/projects/SolarLight/SolarLight.html) are very similar (I think), but again there's only one batter and an induction coil. Is there a benefit to these? Also, this website discusses a lot about oscillations and positive feedback. I don't know much about this, and it seems that this is more of a complex version. I don't know :confused:
Basically I'm looking for a relatively easy, but enjoyable way to fix this lamp. I'm a beginner with electronics. I can solder, and have access to the majority of equipment that I *think* I need to fix this. Any info would be GREATLY appreciated.
Bryan
Here's a circuit drawing of the 555 which I was thinking of using. Would it work?
  • IMG_0001.pdf
If your solar cells put out 0.2W in direct sunlight, then your 2160mWh (900mAh * 2 * 1.2V) of batteries will be about 65% charged after 8 hours of noonday sun. But it isn't noon for 8 hours straight! So the battery will be about 20% charged or less (400mWh) after a very sunny day. At night, if the 8 LEDs draw only 350mW (10mA into each LED at 3.5V) total, you'll get 1 hour, maybe a little more.
There is no 555 circuit that can improve this. You need a more powerful (larger?) solar array.
What if I were to only have one battery? Would that workout better?
I don't remember such a detailed original post. :eek:
I've been doing a *lot* of research lately, and I want to get everything right :D
A single battery wouldn't change the total energy available. You need more efficient or larger solar cells, and/or more efficient LEDs. The battery doesn't figure in the equation unless it's not big enough. In the scenario I see, one cell should be enough. Using two makes some circuits easier to design.
So if I were to build this, which option would be the best to use? A timer or non-timer circuit? If non-timer, which one would be more efficient and why?
The 555 circuit has some flaws; mostly if Vc is greater than the turn on voltage of 2 LEDs in series they both will be on without current limiting.
I like the talkingelectronics circuit #2 best because it only needs one inductor, but I also like the way circuit #1 doesn't need a CdS cell.
Either circuit might over-discharge the NiCd if it doesn't get any light for a while (such as in storage or the winter). And note that they can use NiMH instead without any changes.
Would this be the same if it's with 8 LEDs in series?
Is there any way to prevent the over-discharge? Could I use a diode somewhere? If so, where?
I truly appreciate your help :D
I missed the part where I said doublers would not work.... I just don't like two LEDs in series without any current limiting.
I'm sorry, I took this to mean that a 555 circuit wouldn't effectively double/multiply the voltage.
I guess I was thinking of making the main circuit look like this [solar circuit.pdf]. Depending on how much power I need to give to the LEDs (would it be power, voltage, or current that I'd be worried about?) I would assume that I'd have to have a doubler/multiplier hooked up [doubler.gif]
I guess the main hook-up would be the solar panel to the doubler, and then the Vsource of the doubler lead into the +Vs on the solar circuit.pdf (remove the solar panel).
Would that work?
  • Solar circuit.pdf
The 555 can double the output voltage, but the resulting current will be 1/2 (no new power created). And, the 55 driving the LEDs would make them flicker like you want, providing the Vs is less than 8*Vf of the LEDs.
But neither circuit will create energy. All of your energy must come from your solar cells.
I should correct that: The 555 requires 4.5V input before it can double anything. It cannot double 1.2V from a NiCd or NiMH.
A.) Would I have the same issues with a voltage multiplier (increased voltage = decreased current)?
B.) I'm starting to think I'm getting caught up on semantics. Which should I be more interested in when looking at powering (lighting) LEDs: voltage, current, power (you mentioned power in an earlier post)?
voltage = potential to do work
current = movement of electricity
power = rate that energy is used in/by the circuit
And, the 555 driving the LEDs would make them flicker like you want, providing the Vs is less than 8*Vf of the LEDs.
C.) If Vs is 2V from the solar panel, and I have 4 LEDs hooked up in series (in my diagram), would they light up properly? Should I use a resistor? If so, what resistance/how would I calculate that?
A) Power is voltage * current. Power is constant (minus losses).
B) The LEDs require voltage to light, but current defines brightness. Current is P/V.
C) If Vs is 2V, the 555 won't do anything. It requires 4.5V.
Things are *much* clearer now. Thank you.
The 555 circuit does not double the voltage because its output has a 1.5V loss and the diodes add another 0.7V loss.
The battery must be higher than 4.5V so four Ni-cads can be used to give 4.8V.
The output voltage from the "doubler" is only 5.7V at low currents and is less at higher currents.
White LEDs are about 3.5V. Two in series need 7V but the doubler circuit does not supply enough voltage.
A Cmos 555 works with a supply as low as 2V but its output current is very low.
The Maxim IC will work if you have 2500mAh Ni-MH cells and a huge solar panel.
Plus I think you only get out about 2/3 of the energy you put into batteries.
If there were a way around this they would have done it.
These solar lights are supposed to be wish-fulfillment for people who don't want to pay an electrician, except that the wish is not fulfilled.
Just like these battery-operated stick-on closet lights, some of which have a bulb that looks like a standard 120 V bulb.
The FTC seems to be sleeping.
I put in a bunch of outside walkway lights that ran on a 12 V transformer for a neighbor, and each bulb put out 4 W. They weren't all that bright, either.
4 W in an incand. is probably 0.8 W in an LED.
Another way around the NEC is to trickle charge the batts with a low voltage charger located in your house. Almost any skinny wires could carry this current.
