| Renewable Energy Discussion of Solar, Wind, Hydro and main stream renewable energy topics including RE projects. |
Yep, it's me again >_> , taking advantage of this great forum Anyway... I'm looking for a simple circuit about solar power supply with a backup power for nightly operation. The circuit I have consumes 20mA @ 5V (it is a clock + thermometer ) Links and ideas are welcomed | |
The CLock/Thermometer looks really cool! For a House supply oops (EDIT) As for Solar power back up, I would get high wattage solar panels and charge up a battery bank (think car batteries) and run a 120VAC inverter on it. Not very descripitve, but should point you in the direct direction. FOR YOUR CIRCUIT Seeing that it only draws 20ma at 5V, lets make it safe that it could for what ever reason start to want 50ma. I would get a 6W solar panel (12V 500ma) and run that into a 5V regulator. That should work great, and for night time put a 9.6V battery or whatever voltage would suit it and attach that across the input voltage (12V solar panel) and ground it electrically to the solar panel. Make it a NiCd or NiMH. This is just a vague suggestion, I would wait for some of the other pros to state their opinion too. Good Luck
__________________ IF YOU WANT TO HELP FINE IF NOT PLEASE DON"T PEE IN MY CHEERO'S | |
i would def go for batteries meant for use with solar panels, cos car batteries are ment to have large amount of power drawn from them and are not so good for long "light" discharge
__________________ The best is yet to come Good enough - its perfect !! 2 Gig of free online backup space ![]() cq cq de LA3BNA | |
Six NiMH cells powering a LM2936-5.0 will do. You can eailly trickle charge the batteries at C/10 using a simple series resistor and schottky diode, to prevent them from discharging back into the solar cells.
Any schematic 999? >_>
| | #6 |
The circuit for the LM2936-5.0 can be found on the datasheet. Here's a circuit for a simple battery backup. http://www.electro-tech-online.com/a...ple-dc-ups.pdf DC UPS Circuits Replace the 1Ω resistor with a higher value that will trickle charge the NiMH cell at a safe current. Replace Rl with the LM2936-5.0 circuit.
| | #7 |
Thank you for the info Hero999 | |
| | #8 |
ooooppsss I guess i missed about the battery sizing all together
| | #9 |
Thank you for the information
| | #10 |
It looks like the LEDs consume most of the power. Is it feasible to turn them off, or reduce the power to them?
| backup, power, solar, supply |
| Good Electronic Supply's Sites, Everyone Come On In! :P | Electric Rain | General Electronics Chat | 44 | 28th August 2007 12:06 AM |
| Got a new EVBoard How do i supply power to it? | cubdh23 | Micro Controllers | 2 | 3rd August 2007 10:39 AM |
| Capacitor based power supply | dadwhiskers | Electronic Projects Design/Ideas/Reviews | 6 | 28th April 2007 09:42 PM |
| Draining capacitors on power supply | hfireworks | Electronic Projects Design/Ideas/Reviews | 24 | 27th April 2007 03:03 AM |
| Power supply/ current supply design | inkedallusion | Electronic Projects Design/Ideas/Reviews | 1 | 17th December 2002 02:10 AM |
