+ Reply to Thread
Results 1 to 7 of 7
Thread: A small wind power project
  1. #1
    Green_NRG Newbie
    Join Date
    Nov 2007
    Posts
    1
    Default A small wind power project
    First off I'm new to this forum and I would like to say hello to all.
    I have been very interested in building a wind generator for some time now, I have done some research into it and have come up with some ideas. I thought I would post here to see what you experieneced guys thought.
    My goal is to power one light, enough to illuminate a room 3.5 Meters x 6 Meters X 3 Meters high. I am relatively new to electronics and have only made myself crossovers for speakers, but saying that I feel confident that with a lot of reading and guidance from more experienced people like yourselves, I could achieve this project.
    I have done some extensive research and have come up with two ideas that I think maybe suitable for the generator.
    One of the problems I have is, I must keep the blades rather small and I also can't go to high off the roof. I live in a top floor apartment and have access to the flat roof above me. There are chimney stacks which I can brace too, I have already braced a satellite dish to one side with no problems from neighbours, so a small windmill should be ok.
    I was thinking of using a Sturmey Archer GH6 Dynohub or equivalent, the Dynohub is actually a multi pole alternator that would produce alternating current. I found this site with more info about this, there is a small video showing the guy powering a 12 Volt 11w Compact Fluorescent lamp.
    http://www.gotwind.org/Dynohub.htm
    My question with regards to the set up in the video, could I connect a 12Volt 11w Compact Fluorescent lamp directly to the multi pole alternator with just a manual on/off switch on the + side. Or would there be a problem with the generator still producing electricity while the switch is turned to off? Am I right in think there is no need for a blocking diode for a multi pole alternator roducing AC?
    I also found the Windbelt interesting and wondered how hard it would be to make and would it produce enough energy to power a 12 Volt 11w Compact Fluorescent lamp?
    http://www.popularmechanics.com/tech...html?series=37
    Your views and opinions would be most valued, thank you.
    Darron
  2. #2
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,865
    A windmill generator or alternator always needs a load. Without a lod (when you turn off the light) will cause its RPMs to be so fast that it falls apart. The same thing will happen in a high wind when the electronics in the bulb burn out and leave the alternator without a load.
    Some wind generator controllers have a dummy load that is automatically switched to the output if the RPMs get to be too high.
    Very good wind generators have variable pitch on the propeller blades. They can even 'feather" the pitch so that the prop doesn't turn in extremely high winds.
    Fan-jet airplanes have variable-pitch props. When they are slowing for a landing and make a big noise do they use negative pitch for reverse thrust to slow down??
  3. #3
    mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,821
    He's demonstrated 40 milliwatt output in a 10 MPH wind.
    To drive a Fluorescent lamp, you would wind the coils differently (more turns, thinner wire) and skip the rectification and oscillator stages. That is, after making the jump from 40mW to 11W.
  4. #4
    things Good things Good
    Join Date
    Jan 2007
    Location
    Cairns, Australia
    Posts
    742
    Well you would want to use some kind of battery, for a dummy load, and if its not windy when you need the light.
    The 3 laws of science....
    1. If it smells bad, It's chemistry.
    2. If it's mushy, It's biology.
    3. If it doesn't work, It's physics.
    www.laserchat.org IRC chat for laser and electronic related stuff.
  5. #5
    viper77707 Newbie
    Join Date
    Nov 2006
    Location
    beaumont tx usa
    Posts
    42
    well florescent lamps have a high voltage converter to run them..you would have to measure the input to get the amount of current you REALLY need..the driving electronics for the high voltage supply use some electricity and the transformer uses alot(quite a bit) more energy than it puts out.hope that helps you
  6. #6
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,791
    Quote Originally Posted by viper77707
    Actually correctly designed transformers are one of the most efficient machines in the world!.
  7. #7
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    13,120
    That depends on the quality and size of the transformer, a crappy little 1VA wall wart might only 50% efficient whilst a 1GVA might be 99.99% efficient.
    A 22W fluroscent tube ballast is probably about 80% efficient but that's before you take in to account the poor power factor but most modern fittings have a capacitor built in so it isn't normally a problem,
    if I know the answer.
+ Reply to Thread
  1. Help me design a new car power supply project
    By dave3141 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 7th August 2006, 05:31 AM
  2. I want to design very very small 6V power supply @100mA
    By nikhil arora in forum Electronic Projects Design/Ideas/Reviews
    Latest: 29th June 2006, 03:51 PM
  3. Small power amplifier
    By Dr.EM in forum Electronic Projects Design/Ideas/Reviews
    Latest: 5th June 2006, 10:03 PM
  4. small servo project, I really need HELP
    By fakahany1 in forum Robotics Chat
    Latest: 3rd August 2004, 12:36 AM
  5. My Power Project
    By zeewatcher in forum Electronic Projects Design/Ideas/Reviews
    Latest: 21st April 2004, 06:11 PM
Tags for this Thread
