| Renewable Energy Discussion of Solar, Wind, Hydro and main stream renewable energy topics including RE projects. |
My 3 year old 100AH battery used for a 500 Watt inverter will not take charge beyond 13.2 Volts...used a high current pulse charger still no luck !! the floating voltage is around 12 volts...no internal shorts...any help will be appreciated !!
| | #2 | |
| | #3 | |
They usually Last Longer for this type of use.
__________________ I No Longer accept Private Messages on here. All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\" or they go Directly to my Junk Mail Folder. Email me at: chemelec@hotmail.com Website: http://www3.telus.net/chemelec | ||
Its tubular...Deep cycle battery....I still believe it can be recovered..by high current pulse charging !! to remove sulphanation U have mail Chemelec Last edited by sivankls; 13th July 2007 at 06:17 AM. | |
Basically all your saying is your 100 a/h isnt keeping charged. Now what voltage is it, how are you charging it and as Chemelec says is it a deep cycle battery. You also dont state what devices you are using and what charge controller you have to keep the battery in a good charging state. Provide all the answers to the questions above then maybe we can provide some answers to your problem. I'm not being mean just without any real information I can't give you a decent accurate response. Cheers Bryan
__________________ " The only way to avoid human error is to avoid the use of humans" | |
| | #6 |
The charger is a Constant voltage current limited charger...the open circuit charger output volts is 14.0..the current is limited to 6 Amps..but falls off to nil when the battery charges to 14.Volts.With this charger, the battery gets to 13.2 volts..then I tried a pulse charger, the battery gets slightly hot and the acid bubbles..but still the battery volts is 13.2Volts..
| | #7 | |
Lets know what it is. | ||
| | #8 |
What if its lower or higher...Should i change the acid or clean the cells and again add the acid ?
| | #9 | |
A local garage should have a hydrometer to check it, lets know what it is? A one time you could buy made up battery acid, I used to charge up the battery and check the SG of each cell and top up with battery acid as required to get the SG to near 1.280. | ||
| | #10 |
A local auto electrical shop had it checked (SG) they say its almost normal...They simulated cold cranking with a device drawing very high current, the battery dropped to 8.5 volts but observed small bubbles (gassing ?)....What they say is its almost end of life..but I still hope it can be recovered by high current pulses!!!
| | #11 | |
NOT a Sulfation problem. Get a New Battery. And if your using this battery in a Standby situation, your charge voltage should be about 13.6 volts. Not the 14 to 14.6 volts as used in a Cycle sitiuation, like in a car.
| | #12 |
The no load battery volts is 12.45.... | |
| | #13 | |
http://www.wind-sun.com/PDF_Files/battvoltandsoc.pdf http://www.jstage.jst.go.jp/article/...9_265/_article | ||
| | #14 |
You might consider running your actual load and see how the battery performs. If your battery is in any type of critical application, you should consider this against the cost of a new one when deciding your strategy. Also, consider the cost of your time determining what to do with an aged battery compared to just getting a new or professionally restored battery. If you get a new battery, you have the opportunity to actually get the correct type. | |
| | #15 |
Therz marked improvement in the condition of battery..I have set the pulse rate as 0.5 second ON 3 seconds OFF..Now no warming or excess gassing up of battery..and with charging for 4 days the battery volts have risen to 13.8Volts...the no load battery volts after disconnecting charger and measuring after 6 hours was 12.9 volts..now I need to measure the AH capacity...
| battery, charged, fully |
| primitive early design for battery charging | faomari | General Electronics Chat | 40 | 13th September 2009 01:46 AM |
| Replacing a Battery | DirtyLude | Electronic Projects Design/Ideas/Reviews | 5 | 13th July 2005 01:55 PM |
| Keeping a battery charged between two voltages | Jules | Electronic Projects Design/Ideas/Reviews | 1 | 24th July 2004 03:14 PM |
| Keeping a battery charged between two voltages | Jules | Electronic Projects Design/Ideas/Reviews | 5 | 23rd July 2004 02:03 PM |
| Charged battery the wrong way! | hantto | General Electronics Chat | 2 | 28th January 2004 09:23 PM |
