+ Reply to Thread
Page 3 of 4
First 1 2 3 4 Last
Results 31 to 45 of 52
Thread: Satelite dish solar collector
  1. #31
    Sig239 Newbie
    Join Date
    May 2006
    Location
    USA-Ohio
    Posts
    202
    We have some fresnel lenses at work (the ones we play with are about 24" by 36"), we burn holes through steel 5 gallon buckets with it. And like mramos1 said, concrete just pops apart. As you bring it into focus on something combustable, it just bursts into flames. This doesn't even touch the power of a 10 ft. dish. Also with a clear piece of plexiglass you can focus through it onto something behind it, however it does get warm as the plexiglass will absorb a little of the light. On the other hand if the plexiglass has any tint to it, or any coating, it will burst into flames.
    Another word of caution, if you decide to play with lenses of any apreciable power in this fashion, then you should be wearing 100% uv protective eyewear. The reflected light will have you seeing spots for quite a while at the very least. I'm quite a bit further from the equator than Florida, so I imagine the hazards are at least a little bit greater.
    Anyways sorry about the ranting, I promise I will quit now.
    I wish I had a 10 ft. parabolic dish to play with...lucky...lol
  2. #32
    HarveyH42 Excellent HarveyH42 Excellent HarveyH42 Excellent HarveyH42 Excellent HarveyH42 Excellent HarveyH42 Excellent HarveyH42 Excellent
    Join Date
    Feb 2006
    Location
    Florida
    Posts
    3,081
    I got both of mine for free. They aren't used that much any more. If you see one in a neighbor's or relative's yard, just ask. Also, if you drive/walk by one that looks a little overgrown with vegetation or poorly maintained, it probably hasn't been used in years, ask the owners. The 10 foot dish with the mounts removed is around 100lbs (probably less). I can pick it up and move it, a little ackward, so two people would have no problem. Most people think about alternative uses, like the roof for a small shed, but never get around to it. There are a lot of people who would loved to get the eye-sore off the property.
  3. #33
    mramos1 Excellent mramos1 Excellent mramos1 Excellent mramos1 Excellent
    Join Date
    Sep 2005
    Location
    Boynton Beach, Florida USA
    Posts
    2,254
    My neightbor has one, but I do not want it. I just cut up my 12 footer last year
    I still have the mounting pole. Serious iron pole if anyone wants it.
  4. #34
    Aphromann Newbie
    Join Date
    Aug 2006
    Posts
    15
    So then are you going for a death ray? because myth busters and MIT found it to be impractical. I would suggest a napalm substitute or a piece of experimental rocket fuel. The current fuels are pink and look like rubber erasers and have the power to burn a hole through concrete. And if your just looking for temperatures, depleated plutonium.
  5. #35
    Join Date
    Sep 2005
    Location
    Posts
    2,254
    Quote Originally Posted by Aphromann
    My lens will do that or a microwave heated rod.. We all love the show. But if I could get in the focal length of my lens. The ship would sink. No doubt. And it would not take long.
    No reason to bring in the chemicals. We all take in enough of that stuff..
  6. #36
    justDIY Good justDIY Good
    Join Date
    Mar 2005
    Location
    Michigan, USA
    Posts
    1,725
    Quote Originally Posted by mramos1
    Maybe they are thinking microwaves? I have stood in front of mine many times.
    I'd wager the leakage from a microwave oven is higher than the levels present at the collection point of a satillite dish.
    If you don't have a planet, what good are gold bars?
    want to contact me directly? gmail gordonthree
    check out my project website: http://projects.dimension-x.net
    Favorite numbers:
    09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
  7. #37
    Join Date
    Sep 2005
    Location
    Posts
    2,254
    I just saw it somewere on the net. Some college has a microwave drill that will do glass and concrete.. That I would throw that in the mix.
  8. #38
    Aphromann Newbie
    Join Date
    Aug 2006
    Posts
    15
    Caramel will eat through a steel ship after so many years. Put kerosean on the boat before hand, and then fill the cabin with liquid hydrogen, and there should be a magnificant explosion. Or build a catapult to through hot red coalsat the boat.
  9. #39
    cchance Newbie
    Join Date
    Nov 2006
    Posts
    1
    Im new to the board but heres my suggestion that i can almost guarantee will work
    Buy a roll of mylar film great stuff its around 98% reflective, its lightweight so best to do it where there isnt too much wind. Use some adhesive spray on the mesh and then with a soft brush smooth down the mylar onto the adhesive covered mesh
    Tada Once completed should have a hella parabolic reflector i'd suggest not putting the mylar on in sunlight or cover the work area with a tarp or something similar.
  10. #40
    Join Date
    Feb 2006
    Location
    Florida
    Posts
    3,081
    Wind? in Florida...? Considing the past two years, this year was a total shock. We didn't even get a real bad thunderstorm. Guess God is giving use a break after all we went through in 2004, or saving it up for next year...
    I don't have a garage or shed (build one some day...), so doing this is just a real short term experiment (not a great motivator). I have the mylar (sort of bubble-wrap, packaging material for frozen food products from the warehouse I work in).
  11. #41
    Join Date
    Sep 2005
    Location
    Posts
    2,254
    After Jeanne, Fransis and Wilma, we needed it.. Gusty down here today. 15-20MPH, yesterday 35MPH gusts. But I will take them over 130 ANY day.
  12. #42
    theinfamousbob Okay
    Join Date
    Apr 2005
    Location
    Cleveland, Ohio, USA
    Posts
    546
    Blog Entries
    2
    Can you get some thicker aluminum/steel sheeting (1/16")? If so, you could just use the existing parabolic frame and nail it in...give it a good polish and buffing after.
    I've always wanted one of those dishes...I'll see 'em now and again on the side of the road. Too bad my parents won't let me take one.
    It'll have to go on the back burner along with my white unmarked utility van stuffed with rack mount servers in the back...
    -Ian
  13. #43
    Join Date
    Sep 2005
    Location
    Posts
    2,254
    I know there is one across the street from my house if someone wants in. Florida, USA. My wife would kill me if I brought it home. I cut my 12' one up years ago after a hurricane convinced me to get a smaller one.
  14. #44
    tytower Bad tytower Bad tytower Bad
    Join Date
    Oct 2006
    Posts
    195
    I see nobody else has posted how to get the focal length .
    Measure the depth of the dish from a straight piece of timber set accross its face .
    F=DxD/16d where D=Diameter of dish and d=depth of dish
    Thats D squared divided by 16 times the measured depth
    The satellites are 32,000 kms out in space ,very hard to get any signal to the receiving point. It won't do anything to your head.
    The Mylar suggestion however is worthy of experimentation. Do they make it any more reflective than that ?
    The Microwaves discussed are not the same frequencies
    My Property and my Family are not for Govenments to control.That is not the purpose of Governments.
    To stop corruption in Government officials give them three times the penalty. They should, and do, know better. Let them commit to that when first employed
  15. #45
    Sig239 Newbie
    Join Date
    May 2006
    Location
    USA-Ohio
    Posts
    202
    Quote Originally Posted by tytower
    Maybe the microwaves won't, but the solar energy sure will. Especially if your in the sun while applying that mylar, and your head passes through the focal point (and of course it will)! How long do you think it will take to fry the retinas out too? ooouuuch
+ Reply to Thread
Page 3 of 4
First 1 2 3 4 Last
Tags for this Thread
