Limit the Speed of Turbine Generator
« First 123
  1. #21
    duffy duffy is offline
    Stepper might be the solution, but I think you said you were testing for "turbulence", right? This is going to be sensitive to variations in rotor speeds, those Reynold's numbers and all. A stepper is going to give you a lot of "jumps". If you are seriously doing turbulence tests it seems like you would be more interested in the smooth rotational velocities afforded by a powder clutch or something else.
    Quote Originally Posted by cloakinghalk View Post
    With that large gear ratio I think it might slow down the blade to the point that it would be slower than the critical speed I am looking for.
    What, 25 RPM? That's s-l-o-w. Your "outrunner" motor spins over 8,000 RPM, and you can see those prop motor gearboxes are nowhere near a 320:1 ratio.
    Something's just not adding up here. What are you using to measure turbulence?
    0
    Please respond to items in forum, not in private messages.
  2. #22
    alec_t alec_t is offline
    let the turbine turn the motor while the resistance in the potentiometer is high then to slow down the motor, lower the resistance. Would this work or is it bad to do this?
    I think you're on the right track there.
    You said you can stop the turbine easily with a finger. Suppose you need a force of 1 lb at a radius of 6" to do this. That means the turbine torque is 1 x 6 / 12 = 0.5 ft.lb, so the turbine energy output is 0.5 x 2 x pi x 25rpm / 60 = 1.3 ft.lb/sec = 1.8 Watts. Hence if the stopping force were 5 lb then the energy would be 5 x 1.8 = 9 Watts.
    The motor you linked to is rated at ~ 200 Watts peak. Let's allow a hefty safety margin and say 50 Watts. That's far more than the 9 Watts output from the turbine, so if you apply a variable current to it and use it as a motor (not generator) to attempt to drive the turbine backwards through 1:5 gearing you should get the braking effect you want. The motor will be operating under stall conditions because it's trying to drive one way but the turbine is forcing it the opposite way.
    Edit: At 50 Watts using a 10V supply the motor the motor needs 5 Amps. So a potentiometer (unless a high current expensive one) won't cope. A PWM-controlled FET would be better.
    0
    My circuit designs should be regarded as experimental. Although they work in simulation, their component values may need altering or additional components may occasionally be necessary when the circuit is built. Due safety precautions should be taken with any circuit involving mains voltage or electrostatic-sensitive components.
    Alec's First Law:-
    Every problem has a solution (given the right information and resources).
  3. #23
    cloakinghalk cloakinghalk is offline
    @Duffy Yes I have a spare stepper motor and felt those jumps while turning the shaft. That might cause problems when viewing the wake behind the turbine. To measure the turbulence I am using PIV to look at the vortex shedding off the tip of the blade. The turbine does spin pretty flow so that's why I mentioned before that I wasn't sure if I should buy one of the outrunners. I only found them because I wanted a brushless motor. The brushed motors have that same type of jumping effect that the stepper does and is harder to turn.
    @alec_t So if I can find a smaller motor then I should be able to use a standard potentiometer? Is it bad to run a motor under stall conditions?
    edit- Looking into it a little more, PWM motor control would probably be better and its not hard to build the circuit
    0
  4. #24
    Sounds like it must be a pretty huge water tunnel to hold a 15" diameter prototype, several hundred gallons at least. Is it your own, or a university's or something?
    The more I think about it, the more I think you might want to bite the bullet and build a custom powder brake. Not only will it give you smooth rotational motion, you could pulse it at various speeds to simulate the periodic angular acceleration inherent with some of the things a turbine blade might be coupled to. It appears to be nothing more than a steel shaft running through the center of a solenoidal electromagnet with some iron filings in the gap and a couple of seals on the ends.
    It's only bad to run a motor under stall if the current is high, and something you can stop with your finger isn't going to be putting 50W of friction power into your finger (unless you are seriously masochistic).
    0
  5. #25
    I am working on this as research for my university. I like the idea of the powder break but building a custom one is probably a little too much work. I think I'm going to try to drive the motor in reverse and stall it. I can find everything I need to test it and see if it works the way I want it to.
    0
  6. #26
    Even a motor at say 1/5 the size is going to take 1 Amp. That's still far too much for a standard pot (which can only handle tens of mA) to be used directly; but a standard pot can control current through a power transistor (FET or BJT) driving the motor. PWM is the most efficient way (less heating of the FET/BJT).
    See post #24. Provided the stall current is well below the maximum specified current for the motor it's perfectly ok.
    0
    Alec's First Law:-
  7. #27
    Reloadron Reloadron is online now
    Would a mag particle brake work out for this?
    Ron
    0
    Please do not PM me with forum related questions. Let's keep things in the open forum. Thank you.
« First 123
Dramatic Video - Wind Turbine Generator Explodes! Analog Members Lounge 9 29th February 2008, 01:48 AM
Hey like my math on the "Beck Mickle hydro generator"? Oznog Alternative Energy 45 17th April 2007, 01:45 PM
Controling the Speed of DC Motor Using PIC??? Ayne Electronic Projects Design/Ideas/Reviews 4 22nd October 2006, 10:35 PM
I Need Help...where Can I Get The Circuit Of Funtion Generator tek_. Electronic Projects Design/Ideas/Reviews 6 19th August 2006, 10:25 AM
Need to log the speed of a racecar. Lm2907 or lm2917? AustinT Electronic Projects Design/Ideas/Reviews 0 27th November 2003, 08:02 AM
Page Time: 0.04771 seconds      Memory: 7,168 KB      Queries: 16      Templates: 0
