Constant Voltage Solar MPPT
  1. #1
    Mohamed Najiullah Mohamed Najiullah is offline
    I'm trying to do a project on Solar Maximum Power Point Tracking as part of my final semester. I did some basic reading on the types of MPPT and found an interesting type called Constant Voltage MPPT.
    http://en.wikipedia.org/wiki/Constant_voltage_method
    It says that the problem associated with this type is that there is a frequent need to disconnect the circuit in order to measure the output voltage and then set the optimum voltage to 0.76 times the actual voltage of the Solar Array.
    My question is if i use a timer circuit or a microcontroller with a power semiconductor device like an IGBT or a MOSFET and set the duty cycle to 0.76, will it suffice? And if yes wouldn't this eliminate the need for opening the circuit for measuring?
  2. #2
    RCinFLA RCinFLA is offline
    No, because of variable illumination current, Rs of cells and switcher circuitry, the switcher duty cycle must adjust to account for these changes. The 0.76 has nothing to do with switcher duty cycle.
    The switcher regulates based on input voltage sense instead of conventional switcher output voltage sense.
    The "0.76" factor between Voc and Vmp depends on series resistance of cells and their illumination current output. I would say 0.76 is too low. At 25 degs C Vmp is about 0.52v where Voc is about 0.66 vdc. Mono-crystaline cells have lower Rs and the factor would be more like 0.81. Poly-crystaline would be more like 0.79.
    You want to avoid going too high in voltage where inherent cell diode conduction goes up exponentially so the 0.76 is likely to ensure you always stay down on the more constant current region. You will loose some available power by doing this over a more efficient MPPT algorythm.
    If charging a battery the simplest and most effective MPPT algorythm is to just maximize the battery charging current.
    0
I need a constant voltage output circuit for a solar cell (Zener/Voltage Regulator?) ashour Electronic Projects Design/Ideas/Reviews 9 3rd April 2011, 09:13 PM
a constant voltage and a current source neo_star General Electronics Chat 1 24th March 2009, 01:27 AM
constant voltage, constant current Lead Acid Battery Charger Erwin_Macaraig Microcontrollers 1 4th October 2008, 12:26 AM
Getting constant voltage abuthemagician Electronic Projects Design/Ideas/Reviews 21 9th June 2007, 04:02 PM
low power constant voltage source yagtoby Electronic Projects Design/Ideas/Reviews 1 25th June 2006, 02:47 AM
Page Time: 0.04944 seconds      Memory: 7,177 KB      Queries: 16      Templates: 0
