Transistor FM Superhet -Initial experiments
12 Last »
  1. #1
    transistor495 transistor495 is offline
    G'day guys!
    I've carried out some quick experiments after the arrival of my new RF Signal generator/counter. This is one of that. A transistorized FM superhet receiver which can demodulate and output broadcast band FM stations.
    But the interesting thing is that I have started with a basic Medium Wave receiver circuit with 455KHz two stage IF and basic germanium diode AM detector. This one was a big success and I could receive the local AM stations clearly and apparently I got surprised a bit on how beautiful is the so called 'superheterodyne' principle!
    The next stage was to remove the oscillator/mixer and detector part from the working receiver to actually convert it to an FM receiver. So I've added a simple charge pump FM demodulator consisting of 2 BC547's and a BF494 wired before the IF stages as a simplest mixer. Being connected with just a 5" antenna at the emitter of the transistor and Signal Generator output injected to the base in place of LO, let me say I'm quite surprised that the system could clearly receive couple of strong local FM stations nearby.
    For 102.3MHz, I've injected around 102.9MHz to tune in the station clearly.
    No tuned input circuits employed as of now and the whole circuit is powered using 3V(2xAA cells)
    Next part would be to add an RF amp and LO so that to achieve a stand alone working FM receiver and I feel pretty confident that that would be so simple actually!
    Below is the current status on breadboard, and you can see the signal generator outputting 102.9MHz used for ~455KHz down-converting for the receiver.
    Cheers!
  2. #2
    Nigel Goodwin Nigel Goodwin is offline
    Super Moderator
    I'm amazed you've got anything out of it, breadboards aren't suitable for RF - and the layout looks really awful!
    0
  3. Thread Starter #3
    Quote Originally Posted by Nigel Goodwin View Post
    Thanks for your warm concern Nigel
    I would expect the breadboard may create problem while implementing the LO and RF stages because it can certainly affect the desired band coverage. Other than that, the current setup is totally running on the 455KHz IF stage with external oscillator input injected, it seems almost fine. When we move on to higher frequency stages things will become worse I agree. So I may sometimes try the LO part on a separate pcb.
    Regarding the worst layout and look, hey this was a very quick experiment actually done for testing my new signal generator, though it worked
    The audio output is a clean compromise comparing to my previous super-regen.
    I'll try to publish an article with latest circuit once everything is done, and this one uses very cheap components and 455KHz IFT's can be salvaged from any AM tranny/IC radios.
    This one seems very easy
    0
  4. #4
    Super Moderator
    Quote Originally Posted by transistor495 View Post
    So you're taking a radio to pieces to build a radio? - don't you spot the obvious flaw in that?
    Many years ago there was a small junk shop for a while in a small town called Darley Dale, and a friend of mine lived near by - so I popped in once. They had a bucket full of new IF transformers, I often wished I'd bought a pile of them - but I didn't
    0
  5. #5
    audioguru audioguru is offline
    Why do FM radios use wideband 10.7MHz IF transformers or crystal filters instead of the narrow band 455kHz ones used in AM radios??
    Why do narrow band AM radios sound muffled with no high audio frequencies and are distorted, but half-decent FM radios sound extremely clear and produce almost all high audio frequencies without distortion??
    0
  6. Thread Starter #6
    Quote Originally Posted by audioguru View Post
    What you've told I agree with you AG, to be honest I haven't even think about this while building this one and was very quick. I felt I'm missing the treble frequencies a bit in the audio but it's distortion free and lower frequencies are good. This one should provide more than 10KHz of audio bandwidth. Later I'll move on to 10.7MHz IF.
    Nigel, I've collected a bunch of new IFT's before and contains different types may be 10.7 also in them I need to check it out.
    Another thing I'd be experimenting here is the Foster-Seeley discriminator
    I'll add detailed comments later.
    0
  7. #7
    In North America, AM radio stations are 10kHz apart so stations are not allowed to modulate with sound frequencies higher than 10khz to avoid beat frequencies in radios. Most AM radio stations use pre-emphasis equalization to boost audio frequencies from 2kHz to 5kHz to improve the intelligibility of speech through typical radios.
    Wikipedia says that the audio response of the average AM radio is down 6 dB at 3 kHz and down
    about 20 dB at 5 kHz. That is HORRIBLE audio frequency response like a telephone!
    0
  8. Thread Starter #8
    FM use 10.7MHz because it provides better image rejection.
    Dual conversion FM receivers use 10.7(or more) first IF and 455KHz second IF to achieve better selectivity. Still with hi-fi audio.
    If anybody concerned about the speciality of '.7' in 10.7, the reason is that the image frequencies would never fall on any other station as it'll always end up with an even number and the station frequencies will always be an odd ending.
    0
  9. #9
    Hi-Fi FM receivers do not use dual-conversion with 455 IF transformers. Low-Fi communications receivers with poor high frequency response and lots of distortion use dual-conversion.
    0
  10. Thread Starter #10
    Being an audiophile like audioguru, I'd never make compromise on the audio quality of my receiver.
    Currently I"m doing the front-end part of my 455KHz IF transformer(!) based FM wideband receiver
    Let's see and modify later on to 10.7MHz.
    0
12 Last »
A 6 transistor-6 IC dual-conversion superhet SW receiver radiomate Electronic Projects Design/Ideas/Reviews 2 22nd August 2008, 05:35 AM
Transistor Operation ElectroMaster Electronic Theory 1 23rd June 2006, 04:26 PM
Transistor as a switch ARIVOUKARASU General Electronics Chat 3 21st January 2004, 07:24 PM
Transistor base voltage/current? hantto General Electronics Chat 1 8th January 2003, 04:25 PM
help with transistor snidekht General Electronics Chat 3 7th January 2003, 05:28 PM
Page Time: 0.11433 seconds      Memory: 7,734 KB      Queries: 17      Templates: 0
